Need Help....and change your own oil...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Mar 17, 2019.
  1. Mar 17, 2019 at 1:52 PM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Well...this is what I get for trusting the dealership to change my oil.
    The last oil change was at the dealer and apparently they did not read the spec sheet on torquing down the oil filter housing. It's only supposed to be 19 foot pounds.
    When I tried to change my oil today it was so tight that not only would it not turn but I first broke the cap wrench then busted the tabs off the plastic housing...:annoyed:
    Anybody have any ideas on how to get this loose? I'm tempted to put the plug back in the bottom, fill it up with oil and drive with the dirty filter until I can get it to the dealer in two weeks.
  2. Mar 17, 2019 at 1:56 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Definitely upgrade to the aluminum cap!!
    I would run the old filter til the new cap comes in then rip that plastic one out.
  3. Mar 17, 2019 at 1:57 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The plastic swells. You can set it at the factory torque spec and it still be a bitch to get back off.
  4. Mar 17, 2019 at 1:57 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    that's what i would do as you can still drive it.
    i also put the aluminum cap on ... The first time i tried to change mine i almost snapped it... sucks but i think you should be able to get if off , or make the dealer do it ...
    maybe if the oil was warm it may move, some
    Also you can get the new cap and wrench as a combo pack on Amazon
    Genuine Toyota 15620-31060 Oil Filter Cap Assembly
    https://www.amazon.com/Genuine-Toyo...=B008BHP68A&psc=1&refRID=CMHEKBCFQ43Z9S0BVQ5D
    https://www.tacomaworld.com/threads/aluminum-oil-filter-housing-15620-31060.491664/
  5. Mar 17, 2019 at 1:58 PM
    s.e.charles
    s.e.charles Well-Known Member
    share a source for said aluminum cap? thanks
  6. Mar 17, 2019 at 1:58 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Strap wrench
  7. Mar 17, 2019 at 2:02 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Old filter will be fine until you get a replacement.
    GillyLink and shakerhood like this.
  8. Mar 17, 2019 at 2:06 PM
    nevadabugle
    Elko, NV
    Do you guys know, if I fill it back up now, then get the aluminum cap ordered, can I replace the filter without draining all my oil out. Hate to loose 6 quarts of fresh oil.
    Or when I pull the filter will all the oil drain?
  9. Mar 17, 2019 at 2:09 PM
    jerkwithkeyboard
    post #4
    JoeCOVA likes this.
  10. Mar 17, 2019 at 2:10 PM
    nevadabugle
    Elko, NV
    I have ordered the aluminum cap. But I still need to figure out how to remove the one I got.
  11. Mar 17, 2019 at 2:10 PM
    JoeCOVA
    Joe
    Colorado Springs
    I'm pretty sure I remember replacing the filter first and then draining the oil when I did my oil change.
  12. Mar 17, 2019 at 2:12 PM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    This won't void your warranty? Just asking.
  13. Mar 17, 2019 at 2:14 PM
    Flash1034
    N/W Montana
    The aluminum one is exactly the same...just aluminum
  14. Mar 17, 2019 at 2:15 PM
    jerkwithkeyboard
    Shouldn't ? as long as the dealer isn't a dick about it and they did the last one AND you have the right wrench for it i would think not...
    Its for getting it off the cap. not the replacement cap,,, No problem with the cap as it is OEM toyota
  15. Mar 17, 2019 at 2:22 PM
    nevadabugle
    Elko, NV
    Well, plan B is a failure. When the tab broke off it cracked the plastic housing. Soooo, truck is dead until I get this one off and replace with another.
    Still having no luck budging this thing. Strap wrench is a no go.
  16. Mar 17, 2019 at 2:22 PM
    TacomaLite
    TacomaLite Member
    don
    massachusetts
    Use the 27mm on wrench not 3/8
    to loose that thing
  17. Mar 17, 2019 at 2:34 PM
    TacomaLite
    TacomaLite Member
    don
    massachusetts
    Get a hose clamping on plastic housing
    Get the strap wrench over the hose clamp
    May work that way
    nevadabugle[OP] and Flash1034 like this.
  18. Mar 17, 2019 at 2:35 PM
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    Pep boys tends to carry the aluminum housing for the Tacoma, at least the two by my house did. It’s worth a phone call if you want your truck up and running
  19. Mar 17, 2019 at 2:40 PM
    nevadabugle
    Elko, NV
    Thanks all. I got it off finally. I had to wedge the cap wrench on to the housing with a piece of sandpaper inside the wrench for purchase. Then grabbed the outside of the cap wrench with an 18" pipe wrench....
    And it still took all my might to break it free.
  20. Mar 17, 2019 at 2:46 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    I’ll link the best oil filter wrench to use any of the ones that use a teeth suck in my opinion. Broke a housing like this one time because of the poor design. Also snapped the head of the tool once & bent one. This will let you get all the torque down on the housing without stressing the weak points.
    Forged Toyota Lexus Scion Oil Filter Wrench-Chrome Vanadium- 64mm 14 Flats https://www.amazon.com/dp/B01B8O0BFU/ref=cm_sw_r_cp_api_i_3.RJCbS26ZN9D
