NEED HELP ASAP PEASE RESPOND!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTATACOMA09, Oct 10, 2014.
  1. Oct 10, 2014 at 9:26 PM
    TOYOTATACOMA09
    TOYOTATACOMA09 [OP] Member
    Kit
    Johns Creek GA
    09 Prerunner sR5 Double Cab black
    day star leveling kit Satoshi Grille
    I ordered 16x8 6x5.5 rims with +10 offset. I was told that it would fit my truck, but i never saw that it has 4.89 backspacing. WILL IT STILL FIT?! I drive a 2009 double cab pre runner with a 2.5 leveling kit and 265/75/16 tires. please respond as soon as possible. If i get a response soon then i can cancel the order if i have to
  2. Oct 10, 2014 at 9:37 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    here's an idea
    cancel the order till you know
    and save the caps lock, begging for help BS
  3. Oct 10, 2014 at 9:39 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    What he said ^^^ cancel the order
  4. Oct 10, 2014 at 9:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You'll know when they show
  5. Oct 10, 2014 at 9:45 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
  6. Oct 10, 2014 at 9:49 PM
    mountainwolfpup
    Vancouver, WA
    Sorry OP, I see you provided your tire and lift, etc. My mistake.
    Check this out:
    http://www.amazon.com/Helo-HE879-Wheel-Gloss-Milled/dp/B00A8PFJS0
    Looks like similar specs to your rim and the customer comments from an 06 and 11 Taco seem to be pleased with the fit. So looks like they may just fit after all.
  7. Oct 10, 2014 at 10:43 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    They will fit op as long as you run a 265 tire any,bigger you will need a spacer
  8. Oct 10, 2014 at 10:53 PM
    xtyfighterx
    Ty
    285 will rub with that,back spacing on the uca might get away with a 275 but I wouldn't push it
  9. Oct 11, 2014 at 8:23 AM
    xtyfighterx
    Ty
    What,size tire? With a 265 I don't see why they wouldn't work
  10. Oct 11, 2014 at 12:11 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    It will fit fine with that size tire. I use to run 275/65's on a wheel with a BS of 5.4" with zero issues.
  11. Oct 11, 2014 at 12:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I prefer these "omg emergency help" for people with real emergencies.
  12. Oct 11, 2014 at 1:24 PM
    xtyfighterx
    Ty
    Thanks you someone here understands isn't stock wheels 5.5 back spacing?
  13. Oct 11, 2014 at 1:54 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Should fit fine, just more tucked in than other aftermarket wheels. A 0mm to -12mm offset would be more ideal but being as it's only 8" wide its not a big deal. I had 17x9's with 5" BS/0mm offset before and they ran just fine
