need help changing gears
Discussion in '4 Cylinder' started by hooks, Mar 2, 2009.
  1. Mar 2, 2009 at 12:13 AM
    hooks
    hooks [OP] New Member
    hawaii
    07 2.7 4wd single cab tacoma
    k&n air in take, mass air flow sensor, jet cpu up grade, 40 series flowmaster, removed one catalytic converter, has a 8" lift with with 16x10 black alloy wheels and 31x12.50 swamper radials, also custom built rear drive shaft.
    I got a 2007 2.7 4wd tacoma. need help to find out what kind of axle i have so i can order gears. appreciate any help.
    Thank,
    hooks
  2. Mar 2, 2009 at 12:33 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    If you dont have a factory locker, then I think it should just be the standard Toyota 8.4"
  3. Mar 2, 2009 at 6:24 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Is there any identification anywhere?
    I want to upgrade to a limited slip eventually (TruTrac) but the site just lists sizes, not "for your Tacoma PreRunner 4cyl by ...." type info.
  4. Mar 2, 2009 at 6:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should have a gear code on the door jamb. Its a 4 didgit code near the VIN.....looks something like "Bo7A".....It will either start with a "A" or "B", have 2 numbers "07" or something starting with an "0", and end with an "A","B", or "C".
