need help figuring out this button
Discussion in 'Technical Chat' started by Lizbiz, May 5, 2008.
  1. May 5, 2008 at 11:18 PM
    Lizbiz
    Lizbiz [OP] New Member
    sr5
    Hi I was wondering if anyone could help me with what this button is
    suppose to do its the button by the left airconditioning vent? I also was wondering if it was only in the v6 model and the v6 4x4 only. Does that button apply to the 2004 toyota tacoma 4 cylinder automatic sr5 truck?
  2. May 6, 2008 at 10:51 AM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    If I could actually see what's on the button I might be able to help.
    I had a 2000 Taco, so memory is not serving me very well. What is printed on the button?
  3. May 6, 2008 at 1:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can't read it in the picture..but does it say
    "Clutch Start Cancel"???
  4. May 6, 2008 at 1:53 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    doubt it. The picture shows an auto.
  5. May 6, 2008 at 1:59 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    That's your electronic trans control...basically the "power switch"-which is computer controlled to hold out each gear at a higher rpm before shifting into the next gear. Basically to pass, etc.
  6. May 6, 2008 at 2:02 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    And just to let ya know, that other switch closer to the steering column and just to the right of the dash dimmer knob is your rear differential lockout which turns the rear end from a limited-slip to a posi...use only in loose dirt/mud/gravel:)
  7. May 7, 2008 at 3:45 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Technically limited slip and posi are one in the same.
    The button engages the e-locker, which makes your open diff to completely locked.
  8. May 7, 2008 at 4:05 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    If the button says ECT (electronically controlled transmission), then as said before, it's for a little xtra power when passing other vehicles. I'm not sure if it was available in the 4 cyl trucks.
  9. May 7, 2008 at 5:30 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    You're basically saying the same thing I did. My understanding of limited slip is when one wheel starts slipping LS reroutes power to the other wheel...wheras posi is power to both wheels all the time. So who's technical reference are you quoting here...GM labeled their LS as "positraction"-that doesn't make it true posi.
  10. May 7, 2008 at 5:42 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I had a 99 4cyl, and it had that button.
  11. May 7, 2008 at 5:50 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    By the way my last post was in response to zmt's post
  12. May 7, 2008 at 5:52 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I wondered, but figured that was the case.
  13. May 7, 2008 at 5:59 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    In that case I'm glad I clarified Toy!!!:D
  14. Nov 15, 2008 at 12:45 PM
    qgoulden
    qgoulden Member
    Kansas
    '01 V6 4x4 SR5
    I have a question related to the ECT button. If I understand correctly, it helps the transmission shift more efficiently than it might normally. Is this close? I read that it will shift at lower RPM's and that it will lock out of overdrive until the engine is warm. With that being said (assuming it is accurate), is there any problem with leaving it on all the time? Also, does leaving it on affect gas mileage in any way? Any help/advice will be greatly appreicated. Thanks in advance.
  15. Nov 15, 2008 at 1:37 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Mona Lisa Vito: The car that made these two, equal-length tire marks had positraction. You can't make those marks without positraction, which was not available on the '64 Buick Skylark!
    Vinny Gambini: And why not? What is positraction?
    Mona Lisa Vito: It's a limited slip differential which distributes power equally to both the right and left tires. The '64 Skylark had a regular differential, which, anyone who's been stuck in the mud in Alabama knows, you step on the gas, one tire spins, the other tire does nothing.
    [the jury members nod, with murmurs of "yes," "that's right," etc]
    Vinny Gambini: Is that it?
    Mona Lisa Vito: No, there's more! You see? When the left tire mark goes up on the curb and the right tire mark stays flat and even? Well, the '64 Skylark had a solid rear axle, so when the left tire would go up on the curb, the right tire would tilt out and ride along its edge. But that didn't happen here. The tire mark stayed flat and even. This car had an independent rear suspension. Now, in the '60's, there were only two other cars made in America that had positraction, and independent rear suspension, and enough power to make these marks. One was the Corvette, which could never be confused with the Buick Skylark. The other had the same body length, height, width, weight, wheel base, and wheel track as the '64 Skylark, and that was the 1963 Pontiac Tempest
  16. Nov 15, 2008 at 4:32 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Hi buddy:) like I said earlier, it holds each gear (under decent accelleration) to a higher RPM before it upshifts. Your tranny actually shifts more efficiently (as in fuel) with the ECT off because it then wants to shift to the next gear ASAP for economy. Try it yourself on the freeway. Youll notice in ECT mode the tranny tends to wind out the engine a bit more:)
  17. Nov 15, 2008 at 5:56 PM
    qgoulden
    qgoulden Member
    Kansas
    '01 V6 4x4 SR5
    Thanks for the info. One more question, is it best to engage/disengage the ECT power while the truck is in park, neutral, driving, etc. or does it even matter? Just curious. Thanks again...
  18. Nov 15, 2008 at 6:35 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Naw I think it's not a problem-but me being a quirky guy, I will engage mine at a stop rather than in motion. I personally dont use mine much because I like the shiftpoints the tranny uses when ETC is off. If I want more RPMs I'll work the overdrive button or cowboy the gears myself.
  19. Nov 15, 2008 at 6:59 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    I have engaged mine driving down the road,stopped, etc............never had a problem.
  20. Nov 15, 2008 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. It makes no difference weather or not you are moveing or parked when engaugeint the ECT . :)
