Need help figuring out which wire to tap into
Discussion in 'Lighting' started by SoutheastTaco, Oct 3, 2014.
  1. Oct 3, 2014 at 1:03 PM
    SoutheastTaco
    SoutheastTaco [OP] Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Need some help guys.. Most of my previous vehicles had the "puddle lamps" under the mirror that illuminated when I unlocked it, I miss them. I bought some 3/4" LEDs with the rubber grommet and drilled the hole and pushed them into the mirrors. Which wire do I need to tap into to get them to illuminate when I hit the unlock button on my remote? Will they come on when I turn the dome light in from inside the cab? Truck is a '09 sport dc. Thanks.
  2. Oct 3, 2014 at 1:30 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
  3. Oct 3, 2014 at 2:04 PM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    you need to tap the ground from the dome light. It comes down the driverside A pilar. There's a writeup somewhere, keep searching. I think the wire is dark blue.
  4. Oct 3, 2014 at 2:37 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
