Need help finding the right U joints and correct amount.
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpookyBearGarage, Feb 23, 2020.
  1. Feb 23, 2020 at 3:13 PM
    SpookyBearGarage
    SpookyBearGarage [OP] New Member
    The other day while greasing my drive line I noticed a lot of play in my rear most U joint. So I did what I would normally do to fix the problem, search the internet. To my surprise I couldn't seem to find anything conclusive on the correct part and the correct number I need. I have a 2000 4x4 Extended cab with the 3.4L. I counted what I am pretty sure was a total of 6 U joints under my truck. 4 in the rear section (2 on either side of the carrier bearing) and 2 for the front section.
    So with that being said, should I replace all the U joints as I have seen suggested? What is the part I should be replacing it with, I have seen Spicer and Moog recommended for the brand but there seemed to be no consensuses on the part number? Should I replace the carrier bearing at the same time?
  2. Mar 23, 2020 at 1:14 PM
    silverbullet17
    silverbullet17 Member
    Johnny
    2001 Tacoma 4x4 Crew
    I'm trying to find the same info. My u-joints wont take new grease, I'm guessing they've not been serviced in awhile so I figure with all this down time might as well do all the maintenance possible! If you had any luck finding specs and/or part numbers let me know!
  3. Mar 23, 2020 at 1:52 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Mar 23, 2020 at 2:11 PM
    silverbullet17
    Johnny
    being under the California quarantine I have plenty of time but not alot of cash. Any chance you have the specs on the parts needed? Or at least the other u-joints so i can get them replaced? Thanks!
  5. Mar 23, 2020 at 3:14 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
