Need help fixing drivers-side lean
Discussion in 'Suspension' started by Cjanik, Oct 16, 2014.
  1. Oct 16, 2014 at 9:05 PM
    Cjanik
    Cjanik [OP] Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    So here's my situation:
    I had .75 of an inch lean in the front...drivers side was the lower side. (factory suspension)
    So I went out and purchased the OME 9000's with 886x fronts and Dakar/60091 rears. And Icon UCA's.
    Now I have 1.25 inch lean on the drivers side. and that's WITH the 5mm trim packer.
    The rear has a .25 inch lean towards the drivers side.
    My question for you guys is....how can I fix that lean? do I need to add a top spacer on the drivers side to help even it out a little? or is 1.25 an indication of something installed wrong? Is it expected to lean like that? I looked and looked and can't find anything that's loose or installed wrong or out of place. I have the sway bar removed.
  2. Oct 17, 2014 at 6:55 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Search "taco lean"
  3. Oct 17, 2014 at 4:20 PM
    JonEvans56
    JonEvans56 Well-Known Member
    Andrew
    Dead Truck
    Rust, dents, cracking plastic, oxidized paint...
    Its because the driver and gas tank are on that side, so the weight will make it lean. You could use spacers or throw a bunch of weight on the pass. side if you want to be cheap.
  4. Oct 17, 2014 at 4:27 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    Did the springs (dakars) have an "A" or "B" designation on them? Or a "+"? maybe?
  5. Oct 17, 2014 at 4:30 PM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    + or - on the Dakars ?
  6. Oct 17, 2014 at 9:45 PM
    Cjanik
    Chase
    Vegas
    sorry for the delay...long day at work today.
    The Dakars were both +
    its the front thats got the serious lean though? unless your saying the rear is contributing to the front leaning? the rear is very slightly off, its the front thats way off.
    I'm aware of "taco lean", at least to the point of needing a 5mm spacer...is it so bad that its over an inch off and requires a spacer as well?
    here's my readings front the ground to fender...yes I know hub to fender is better but regardless the floor to fender's should be the same (the tires are brand new, same wear and exact same pressure).
    DF: 38.25
    PF: 39.50
    DR: 40.25
    PR: 40.50
    I was reading that adding a 10mm spacer to the drivers side would not only raise the drivers side 10mm, but it would also cause a drop on the passanger side as well? any truth to that? if that would happen, it would bring me rather close to even, although not perfect.
  7. Oct 17, 2014 at 9:47 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Get a chunky gf, problem solved.
  8. Oct 17, 2014 at 10:06 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Or, just get two girlfriends...
  9. Oct 17, 2014 at 10:11 PM
    Cjanik
    Chase
    Vegas
    ^^ they would have to sit on each others lap so that the weight is directed only at the front passengers side....
  10. Oct 17, 2014 at 10:15 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Wrong. One drives while the other sits in YOUR lap.
  11. Oct 17, 2014 at 10:25 PM
    Cjanik
    Chase
    Vegas
    on a serious note....where Can I find a front 10mm trim packer for the tacoma?
    I seem to find a lot for jeeps or expeditions or 4runners etc but no tacomas?
  12. Oct 17, 2014 at 10:28 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Have you tried downsouth motorsports?
  13. Oct 17, 2014 at 10:33 PM
    Cjanik
    Chase
    Vegas
    ^^ just looked now...no luck
  14. Oct 18, 2014 at 8:41 AM
    JonnyBb
    Arkansas
    You could try a top plate spacer. A TP14 (from Toytec) will fit with stock studs installed. About $25 and super easy to install. Any thicker than the TP14 and you would have to switch out the studs.
  15. Oct 18, 2014 at 8:49 AM
    SuperJakeTheSnake
    SuperJakeTheSnake What is this place?
    Jacob
    Jacksonville NC
    02 Toyota Tacoma Prerunner
    Wheelers should have em
  16. Oct 18, 2014 at 8:55 AM
    scocar
    scocar Prebunking
    Did you make sure you have a consistent baseline? By this I mean do your tires have identical pressure (since your measurements are from the ground, not the hub), and did you take measurements with gas tank full, half full, or empty? Also, unload any stuff out of your cab or bed that could be a factor. Just make sure all possible variables are accounted for and measurements are accurate before you start buying stuff for mechanical changes.
  17. Oct 18, 2014 at 10:19 AM
    Cjanik
    Chase
    Vegas
    ^^ yes, I did. I was very OCD about getting correct numbers.
  18. Oct 18, 2014 at 10:21 AM
    Cjanik
    Chase
    Vegas
    That was my original thought but I need twice that lift...more like 1/2 an inch on the drivers side.
  19. Oct 18, 2014 at 10:48 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    The 1/4" spacer will give you 1/2 lift...I would just do that and than call it good...
  20. Oct 18, 2014 at 10:49 AM
    JonnyBb
    Arkansas
