Need help from people who know carb'd v8's
Discussion in 'General Automotive' started by DSMissed, Feb 24, 2012.
  1. Feb 24, 2012 at 5:56 PM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Awesome, thanks for the pics, that always helps. I've got a small to do list from you guys and alot more researching to do, hopefully I'll get it back up and running. Thanks for the feedback so far, and appreciate any further input as well!
  2. Feb 24, 2012 at 5:58 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Do you know what year 350? (it also would help to ID the ignition/Dist.
    I think with GM's the HEI ( i think its called hei ) came out in late 70's , maybe early 80's & the coil was in the dist. cap which was GM's first electronic ign. , its pretty reliable, did you cross any plug wires ?
    I'm thinking tho' that Edelbrock carb will be suspect, they are very touchy & are known to "glitch" pretty regularly... but ya just gotta go over your work again dbl/triple check.. any backfiring /missing when it does run ?
    or does it run smooth more or less & die when you give gas ? (vaccum ?)
  3. Feb 24, 2012 at 6:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I'd do one thing at a time so clean your points, plugs and re-gap, reason for this is your learning and to eliminate one thing at a time you'll then know what affects what. To check your jets simply get to a vantage point where you can see inside the carb, with your hand you can turn the throttle and you will see the mist spray. This likely isn't the reason it won't start but could be the reason for hard starting and shitty power.
    Once its running on its own you can check for a vaccum leak by covering the carb with a towel or shirt(carb will have to be open no breather on top then throw shirt/towel on top), if it dies no leaks, if it still runs you have a vaccum leak to address.
  4. Feb 24, 2012 at 6:05 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I don't know how to tell the year, the original stamp has been removed, and there is a reman stamp from being rebuild and sold as a crate motor, but I researched the number and couldn't get a year from that. The oil dipstick is on the drivers side though, I know that changed sides at some point...
    I definitely didn't screw up wires, I did them one at a time and pressed them on hard. It doesn't do much of anything when it does run, its only seconds, and only while the starter is still helping it out.
    Before when it was running, it would bog down sometimes if I gassed it very hard.
    Heres a pic of the motor, not a good one, but I can try and get a better one tomorrow of the back so you can tell what ignition it has.
  5. Feb 24, 2012 at 6:08 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Thats a great tip on checking for leaks.
  6. Feb 24, 2012 at 6:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's been awhile since I've dealt with anything that old, but many vehicles with points ignition had a "ballast resistor" wired inline with the ignition coil. It dropped the voltage down to around nine volts to make the points last longer. When the engine is cranking the starter solenoid bypasses the ballast resistor and gives the coil a full twelve volts. If the ballast resistor is out, that could be why it only runs while cranking.
    If you pull the air cleaner and get a good picture of the distributor, that would help tremendously. With the air cleaner off, you can also see if the choke is working correctly, and you can look down the carb and see if the accelerator pump is working properly inside the carb. When you push the throttle down, there should be a visible shot of gas in the carb as you are looking down into it. Don't put your face there while trying to start! Just with the engine completely turned off.
    GM HEI ignition doesn't use points. If that's the system you have, it's common to have the ignition modules fail. They frequently will work till they get hot and then shut down, at least in the early stages of failure. Bogging down when giving it gas could also be an early symptom of a coil or module starting to die.
  7. Feb 24, 2012 at 6:35 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Good input, thank you! I will definitely be posting up a pic of the distributor tomorrow so hopefully you guys can tell what type of ignition it has.
    This may also be a problem, but there is no choke hooked up, or not that I can tell. On the ps of the carb, there is a wire hooked up to a knob in the cab that is just loose, has no function. I did order an electric choke a few days ago, hasn't got here yet.
  8. Feb 24, 2012 at 6:49 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I used to always buy manual choke carbs and use a wire to secure them Open/closed basically not working. I would warm the vehicles up using the pedal. Now my winters aren't cold here so no big deal for me.
    For you the loose wire is to be pulled, when done it will choke the engine then once warm you push it back in and then drive on.
  9. Feb 24, 2012 at 6:50 PM
    Ryanp
    Ryanp Member
    Check your timing get a timing light and set it to 12degrees. Or just loosen off the dist and turn it slightly while someone's turning it over.
  10. Feb 24, 2012 at 7:25 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Thats def. an older 350, I'll bet its got a little slide up metal door on the dist. to set points/dwell & it can all be done while running, I was thinking the HEI also till i saw pic & yep was looking for a ballast resistor too.
    I wonder if the dist. has been taken out (180' out) from the way described sounds like it seems to want to fire with starter. (no spark) shoot some starting fluid (if ya have good bluish spark) & see if it will actually run
  11. Feb 25, 2012 at 5:13 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Here's a picture of each side of the carb and the ignition setup on the back. Maybe some of you smarter than me will be able to come up with a year for the motor from what you see. Was too cold to do anything to the truck today, hoping for better weather tomorrow.
  12. Feb 25, 2012 at 8:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well you def. have the HEI electronic ign.
  13. Feb 26, 2012 at 6:46 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    So any guess on what year of truck this motor is from? If I have the HEI ignition, does that mean I have a ballast resistor that is the possible problem?
  14. Feb 26, 2012 at 7:33 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    no ballast resistor
  15. Feb 27, 2012 at 5:49 AM
    #35
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Ok, so I figure this is a good time to upgrade some parts and eliminate some problems. I found a good deal on an MSD cap and rotor.
    Anyone know what year this motor could be though? I'm trying to get a new set of plug wires and I think I need to know the year range for this motor.
  16. Feb 27, 2012 at 7:39 AM
    #36
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Shouldn't make much of a difference, just get wires for a chevy V8, then match them up, as you pull one find one that length from the box.
  17. Feb 27, 2012 at 7:43 AM
    #37
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Huge diff. the HEI wires are alot thicker
  18. Feb 27, 2012 at 10:58 AM
    #38
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    What I mean is when you tell them you have an MSD Cap and you need wires let them know its for a cevy V8 and the box will have the correct lenght wires.
    I was assuming she was going aftermarket with all the new parts not stock.
    Thanks for catching that.
  19. Feb 27, 2012 at 11:37 AM
    #39
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Let's back up over here and work on the basics...The truck I was driving this weekend is a 68 Dodge D100, headers, holley, stage 1 intake, glass packs, so I am VERY familair with old iron.
    Since she is in SD where it is COLD, is the choke working? It sounds like one side bank of the engine gas fouled.
    1) step 1 make sure choke is working, while the electric chokes are nice, they only really work well on stock tuned engines. Bogging/missing when cold is probably a lean condition.
    2) are we getting SPARK at the plugs...get a $5 spark checker at your local FLAP, put it between a where the spark plug goes and ground. Have someone crank the engine, look for a big, fat blue spark. You can gap the spark checker to MATCH your plug gap.
    3) I suspect since this truck probably has modified exhaust/intake it is going be LEAN off idle, and some additional tuning to the accelerator pump/curb idle air fuel mix is going to be needed.
    If you want, email me a hetkind@bestweb.net and can help you get this running off line.
  20. Feb 27, 2012 at 11:42 AM
    #40
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    :thumbsup:
    OP, probably the best way to ID this engine is running the numbers on the side of the block thru a good manual (MOTORS manual used to have a chart but dont know if their around anymore)or parts house, they should know..
    OH WAIT !! better still run those numbers thru a wrecking yard they can DEF. tell you...
