Need help from people who know carb'd v8's
Discussion in 'General Automotive' started by DSMissed, Feb 24, 2012.
  1. Feb 27, 2012 at 1:36 PM
    #41
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i always check for spark first..then fuel.
  2. Feb 27, 2012 at 5:43 PM
    #42
    joes06tacoma
    Joe
    Central Coast, CA
    Keep in mind that whatever year this engine is, it didn't necessarily come with the HEI distributor to begin with. They are really easy to swap. So don't use the year of the engine to order ignition parts for your HEI unit. A late 70's Camaro or chevy truck would probably have that distributor in it stock.
    You can always pull the cap, rotor, coil, module, etc and carry it into the parts store with you. As long as it's a real parts store, there should be someone who can figure out what part numbers you need.
  3. Feb 27, 2012 at 7:59 PM
    #43
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Thats a good point.
    I have tried to find the original numbers on the engine, and it isn't where its supposed to be, I can only find the reman sticker. When an engine is remanufactured, do they shave the original number off? I searched the reman sticker number and didn't find anything. I will try again though....
    I don't believe the choke is working.. there is no knob hooked up, honestly I don't even know which side of the carb the choke cable would be on... I'm going to try and print out some info on the carb from the Edelbrock website, if there is any.
    On a different note though, found this one Ebay:
    http://www.ebay.com/itm/180829752793?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
    Looks like it will work. Can anyone else verify? I understand cap and rotor may not be the problem, but I'd like to upgrade it anyways, and thats a decent deal if its the right one for my engine. Still searching for plug wires. The ones on it are 8mm.
    #43
  4. Feb 27, 2012 at 9:12 PM
    #44
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Oh, I understand that going from breaker point ignition to a "breakerless" HEI is no big deal, but the OP has understand what she has (& i think she's getting a grip on things) Once she ID's year of motor (350's cover alot of years so may not even matter) She can go to any parts house & say "Yeah, I got 1969 chevy 350 with HEI ign. & I need a cap with wires."
    & this assuming it didn't come with it originally, I'm sure she'll get the right parts. & unless there is a particular reason for the MSD parts, I'd just stay with the GM HEI , it packs a hell of a spark (i've been zapped by a few but this one had me almost blacking out...) solid ,reliable & OEM, just my $.02 good luck
  5. Mar 12, 2012 at 7:06 PM
    #45
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Just thought I'd update everyone that I got the truck running this evening, was pretty proud of myself actually!!
    I'm not positive of the culprit because I rebuilt the carb, installed different step up springs and accelerator pump, bought new ignition parts, and replaced a bad spark plug wire. But I think it was ignition related because when I pulled the old cap/coil off, I tipped it sideways and coolant came out. Does anyone know how that could happen?
    Also, before when the truck was running, it would smoke a nice healthy gray. Now that its fixed it is running better than ever, but its smoking somewhat blue with quite a bit of water being expelled. I don't see it deciding to start burning oil overnight, but any other ideas of what that could be?
    Either way, I'm happy its fixed, and can't wait to drive it this weekend now thats it running the way it should! Apparently its been sick since I've owned it and just didn't realize it.. feels like a new truck now.
