Need help identifying this drive-line squeal (video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EatSleepTacos, Apr 15, 2016.
  1. Apr 15, 2016 at 2:01 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Alright guys, I need your help. On my way home from work today this horrendous squeal started. I'm pretty sure I know what'll fix it but I'd like some confirmation. It sounds exactly like a squealing belt, but I promise it's coming from the center support bearing area. It starts up at 30 mph and stops once I decelerate to 20 mph.
    I know it's this because I don't currently have carpet in my truck and can hear the road noise very clearly. The reason I don't have carpet in is most likely the cause of the noise too. I went wheeling last weekend and got stuck in some water, and some of it got in the cab.
    Anyways, it seems like the water messed with the U joint and now (I think) it needs to get regreased. Will this solve the problem?
    Here's a video I took of the noise. You can hear it very clearly because I pulled the grommet out to better hear the noise.
    https://www.youtube.com/watch?v=fkpjOafrU1Q
  2. Jul 3, 2016 at 12:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bump
    So later in the day after this video was taken the squeal self fixed itself (the best kind!). Fast forward a couple months and I went wheeling again and right after the squeal started back up, so it's definitely associated somehow.
    I just greased the U-Joints today with some Mobil 1 Synthetic and usually all the old grease gets pushed out, but nothing was coming out. Went for a test drive and the squeal was still there.
    Thoughts?
  3. Jul 3, 2016 at 12:40 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If your u-joints did not pass the old grease out, then you weren't successful at greasing them - either your grease gun is airlocked, empty, or you simply didn't give them enough pumps. How many pumps did you do per u-joint before you stopped?
    That said, my bet is the carrier bearing is the source of your noise, it doesn't sound like a u-joint from what I can hear in your video.
  4. Jul 3, 2016 at 12:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    More than likely I wasn't successful at greasing them. I just bought it today and was trying to figure out how to use it. I know it was pumping grease, and after about 6 pumps, the new grease would ooze out of the fitting. I assumed I was doing something wrong but I wasn't sure what.
    I was thinking it was the carrier bearing too. Are there any remedies? Or should I just replace it?
  5. Jul 3, 2016 at 12:44 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    CB is sealed and non-serviceable, so would need replacement if it is indeed the problem. Remove the mounting bolts and spin the outer bracket around the shaft , if rough or noisy, then you're confirmed the CB is your issue.
  6. Jul 3, 2016 at 12:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks for the tip. I'll go give that a shot and see what I find.
  7. Jul 3, 2016 at 1:41 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ended up messing with the gun some more and was able to get the old grease out. Went for another test drive and the squeal was still there, although it seemed quieter (probably in my head).
    I unbolted the carrier bearing and inspected it, and it seemed fine. No excess play or anything, just dirty. I'm guessing that some dirt or sand got in it somehow and that's what's causing it.
  8. Jul 3, 2016 at 2:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Shit, I just remembered, my truck is new! I'll just clean it super well, under body and all, take off some of the off-road stuff, and take it to the dealer and see if they'll replace it.
  9. Jul 3, 2016 at 3:35 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    If its a 6 speed. it sounds like the throw out bearing squealing on the pressure plate.
  10. Jul 3, 2016 at 3:39 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's a 6 speed, but it will still make the noise if I'm coasting in neutral. Does that till apply?
  11. Jul 3, 2016 at 4:01 PM
    racer1x
    campbell ca
    05 Taco
    Too many
    Push the clutch in and see if it still makes the noise.
  12. Jul 3, 2016 at 4:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I did some reading on it and the symptoms don't match up. I appreciate the input though!
    I just decided to let the dealer with it and have them fix it under warranty.
  13. Jul 3, 2016 at 4:52 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    CB or U joint. easy fixes, and if its under warranty have em change it.
    EatSleepTacos[OP] likes this.
  14. Aug 3, 2016 at 6:50 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Dealership take care of this under warranty?
  15. Aug 3, 2016 at 7:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I took it in, but they didn't have enough time left before closing to properly diagnose it. I since went out of town, so now I'm waiting for a convenient time to drop my truck off and leave it with them for a saturday.
