Need help identifying this object...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Apr 5, 2012.
  1. Apr 5, 2012 at 10:49 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Anyone know what this is? It's the black tube with the white cap, attached to the side of the glove box, about 1" in diameter and about 3" long. Thanks in advance.
    Mark
    Uploaded with ImageShack.us
  2. Apr 5, 2012 at 10:55 PM
    arsolo
    arsolo Well-Known Member
    Alex
    Lynnwood, Washington
    05 SR5 2.7 4x4
    Brute Force Fab Sliders, Brute Force Front & Rear Bumpers, OME 886 coils, OME Nitrocharger Shocks front and Rear, Icon Progressive AAL, Desert Products Upper Control Arms, Rims, Doug Thorley Header, Borla Muffler, Tinted Windows, Shaved Badges, OEM Fog Lights, Chrome Exterior Mirror Covers, K&N Intake and Filter, Chrome Exhaust Tip, OEM Bug Shield, Tinted Tail Lights, CB, Ebay projector headlights, Shitoshi Grill W/foglights.
    I believe its to slow the speed of the glove box when opening and connects up inside the dash. Easy to put back on but since mine pops off every time I open the glove box i just leave it off. Haven't had any problems with it not being connected.
  3. Apr 5, 2012 at 11:07 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    its like a shock for the glovebox. Mine is crapped out since the mount on the dash side for it is also made of plastic and grew weak and now wont hold it.
  4. Apr 5, 2012 at 11:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yep , glovebox damper
    Hey OP , you get your TPMS reset ?
  5. Apr 6, 2012 at 1:19 AM
    1980 Well-Known Member
    The Dust Bowl
    You will have to take that thing off to change your cabin air filter. I've always found that it's a pain to get to stay back on as the little plastic tabs don't like to bounce back after being squished. I have no idea why they designed it the way they did, probably something that someone thought looked good on paper.
  6. Apr 6, 2012 at 1:26 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    If the plastic tabs the damper snaps over won't hold it anymore because they've been squeezed too many times, I read that you can insert a small sheet metal screw between them, pushing them out, and holding the damper in place.
  7. Apr 6, 2012 at 9:41 AM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Peter, I haven't had a chance to look at the TPMS yet. I'll get to it sometime this weekend and let you know how it goes.
    Mark
  8. Apr 6, 2012 at 9:47 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That object is an over engineered piece of crap...that's what it is.
  9. Apr 6, 2012 at 10:40 AM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/137493-cabin-filter-change.html#post2684203
    Look at the first picture. I had to do this the other day when I changed my cabin air filter because it wouldn't stay on either. I stuck a screw in there like that after grinding down about a 1/4" on the tip of it so it would sit flush. The trick for me was to pop off that little circular cap on the tip of the tube so that it's not airtight. It makes extending inner tube easier. Attach the it as shown in the picture then fully extend the inner tube (I used my finger and pushed it from the inside) and then raise the glove box as much as you possibly can, to the point you are smashing your hand, and you should be able to get that bottom hook around the little snap. Then you have to slowly work your left hand out from behind the glove box while making sure that upper snap thing doesn't come undone. Huge pain in the ass. Don't forget to put that little cap back on the damper tube or else it won't drop down slowly.
  10. Apr 6, 2012 at 8:23 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Thanks for the info Cody. That job does look like a pain in the ass and for no significant gain. Since I am happy with the speed with which my glove box descends, I shall leave that job for the distant future when my glove box descends too quickly or I'm bored out of my head and need something senseless to occupy my time.
    Mark
  11. Apr 6, 2012 at 8:25 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Wow ... I love TW. When I replaced my cabin air filter I had to pop that off and now it won't stay back on. I was just going to cram something into the clip that it snaps over once I put it back on .. something to spread it a bit more and keep in on.
    Thought I was the only one with the problem.
  12. Apr 6, 2012 at 9:44 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Haha I didn't mean to scare you away from it. It's honestly not that bad but it took me a couple tries to get everything back on perfectly. Should only take you a few minutes to put back together. If you have a tiny screw lying around I say go for it.
  13. Apr 10, 2012 at 9:06 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Hi Peter, I finally found the section on TPMS in the owners manual. I'll be resetting the pressure to something like 25 PSI. Then if I see the low pressure icon, I'll know it's serious.
    Thanks,
    Mark
  14. Apr 10, 2012 at 9:09 PM
    OZ-T
    Peter North
    British Columbia
    Just set your tires to the pressure you are going to run them at , and reset the system there , the light doesn't come on unless the tires go down by 5 lbs or so
