Need help installing Axxess ASWC steering wheel controller
Discussion in 'Audio & Video' started by trdracing5, Apr 10, 2011.
  1. Apr 30, 2011 at 6:38 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    What buttons?
  2. Apr 30, 2011 at 6:58 AM
    Bumponapickle
    Bumponapickle Well-Known Member
    Ontario, Canada
    09 TRD + Leather DCLB
    Old Man Emu 3 inch lift + AAL, Satoshi and Pioneer Avic Z130BT
    Installed mine last night with the following connections
    1) Black wire of the ASWC to ground using the same grounding point as the aftermarket radio.
    2) Red wire of the ASWC to a 12 volt accessory wire, one that turns on and off with the ignition key. Same as aftermarket radio.
    3) Connect the Green with Orange stripe wire of the ASWC to pin 7 (violet/white) of the vehicle.
    4) Connect the Black with Green stripe wire of the ASWC to pin 8 (yellow/black) of the vehicle.
    Connected battery, watched the lights blink and at the end would not get a steady red light....reset it again and again....same outcome...screw it and went to bed...over and over in my head of WTF and had an idea....in step one I grounded the AXXESS module, but I did not ground the steering wheel control coming from the vehicle (pin 6 white with red stripe) on the 20 pin connector...did it this morning, connected battery and turned system on....10 seconds and system is working perfect!!!! Hope this helps....
    double_b posted this link where pin 6 is grounded
    http://www.tacomaworld.com/forum/2nd-gen-builds/90547-mike-winterboy04s-tacoma-build.html
    fyi...aftermarket unit is pioneer avic z130bt
    tks
  3. Apr 30, 2011 at 7:41 AM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    Follow the wiring instructions from the docs on their website. The pamphlet that comes with the purchase didn't work for me.
    Doc:
    http://documents.victorytechnologies.com//documents/product/23230.pdf
    Website:
    http://www.axxessinterface.com/
    Mine's been working for a few months and worked really well with the NX501 I have installed. At some point during install I got upset because I was following the paper steps that came with the harness. I e-mailed Axxess techsupport@metra-autosound.com and they replied within a few hours, pointed me to the website docs and then I was up and running.
    Good luck! It's still a good product and worth the extra work.
  4. Apr 30, 2011 at 9:43 AM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    you need to hook the mini jack wire up. the solid brown to ? the color is in the instructions. I think it's a blue wire on the kenwood harness that's labeled "remote".
  5. Apr 30, 2011 at 2:55 PM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Ok, thanks for the info. I am going to install my Pioneer x920bt. I wont ground the red/white, hopefully that works.
  6. May 1, 2011 at 1:34 PM
    reiss91
    reiss91 Well-Known Member
    Mark
    Mass
    2011 Tacoma Gray
    Hooked everything up as it should be. The device recognizes everything is hooked up right and still the buttons don't work.
  7. May 1, 2011 at 1:43 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    what is this? I dont have steering wheel controls but would like to get it. is there an aftermarket kit for my 06? If so let me know where I can get it please thanks.
  8. May 1, 2011 at 4:49 PM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    Hey Jimmy,
    This ASWC is only for Tacomas that already have Steering Wheel Controls. :( You might be able to aftermarket another steering wheel that has audio controls if you really wanted it.
  9. May 1, 2011 at 11:01 PM
    stmpjmpr
    Jimmy
    thanks doc..
  10. May 7, 2011 at 2:38 AM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    R u guys still havin problems wit axxess sw? If so let me know I have it in my 2011 I 4got the colors but ill tear it out 2 help I did have 2 ground 2 chassis though
  11. May 7, 2011 at 7:00 AM
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    I haven't messed with mine since my last posting...but NO I haven't gotten it to work. You don't need to tear your's out.....Thanks for the offer though. I am thinking of taking mine out and hooking to PC and see if maybe it needs updated?
  12. May 7, 2011 at 12:10 PM
    sun
    Memphis
    2011 PreRunner
    im not too worried about taking it out ima probably do it and take pics though i just gotta find time to do it. i installed mine during my lunch break lol so just taking it out and taking pics shouldnt be a prob lol but most definitly ground to the chassis i used the frame behind radio and the power i got from the radio but the data wires are the ones i dont remember and im using a pioneer avh3200bt
  13. May 7, 2011 at 5:39 PM
    RI Tacoma
    Tim
    Phx sometime soon
    2011 Sport DCLB
    I was able to get my axess to work in my 2011 non JBL system. I hooked it up exactly as the directions said (red(from axxess)-ignition, black(from axxess)&red/white(from tacoma) to ground, black/green(axxess)-yellow/black(tacoma) & green/orange(axxess)-violet/white(tacoma))
    The only issue I had was I initially hooked up the green/orange wire to the wrong wire on the tacoma harness, I believe the directions call for pins 7&8 on the tacoma harness.
  14. Sep 7, 2011 at 2:35 PM
    Blewter
    Blewter Under Construction...
    Brandon
    Greensboro, NC
    10 4X2 PreRunner SRS
    tinted windows; alloy wheels; JVC KW-AVX740 HU; Magna Flow Pro Series Exhaust
    I have the same problem. Everything is connected, the module goes through the series of flashes, and then the red light continues to stay on as if it should work properly. But, like you, the controls don't work at all. Has anyone helped you with this? Let me know if you get it working and how you did it. Thanks!
  15. Sep 7, 2011 at 4:23 PM
    #35
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    For guys with Pioneer head units, I can endorse the metra wiring harness made for the the Axxess ASWC works, and is essentially idiot proof (no crimping or soldering needed). For reference: I have a Pioneer X930BT and Axxess ASWC using the OEM steering wheel controls. As an aside, the harness also allows the aux plug on the late models work with the pioneer head units. They were only like $10 at Sonicelectronix, but other vendors probably sell at/near that price.
    http://www.metraonline.com/part/70-8114
  16. Sep 12, 2011 at 4:34 AM
    #36
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I found the Axxess installation manual to be misleading. The pin numbers shown in the picture appear to be looking from the front of the harness connector. I think I finally decided that it must be looking from the back of the connector. If you study the connector and try to match up all the wire colors listed on page 4 of the installation manual, it only works if looking at it from behind. If you look at it from in front, it is easy to mix up the green/ orange wire with the orange/green wire. Wiring convention says the first color listed is the wire and the second is the stripe.
    Also, the grounding is a little confusing. I ran a separate wire to chassis ground from the reference ground connection. Eg, I ran the black wire from the Metra harness and tapped it into the red/white wire on the Tacoma harness. Then I ran a second wire from the red/white wire to chassis ground (a metal fitting on the firewall). I got this hint from some of the Swi-Jack install pictorials- the grounding is the same.
    Here is an excerpt from one of the Swi-Jack install pages- the author uses the radio ground plug, but I am sure it is connected to chassis ground further down the line:
    White/ red stripe
    from Tacoma- (BLACK ground wire from the SWI AND your radio's black ground wire) - yes, you will have your white and red Tacoma wire, connected to the SWI BLACK ground wire that is also connected to your RADIO's black ground wire - a three way connection.
  17. Sep 12, 2011 at 12:05 PM
    #37
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
  18. Sep 22, 2011 at 1:14 PM
    #38
    Blewter
    Brandon
    Greensboro, NC
    It might be a good idea to note that there are TWO violet wires with a white stripe. It took me a while to figure out that I had mine hooked up to the wrong wire purple wire (actually, I sent the first ASWC back!:eek:). But, after I resolved that, the product works exactly as intended.
  19. Oct 24, 2011 at 9:09 PM
    #39
    Thurnis Haley
    Thurnis Haley Member
    Glendale, AZ
    05 TRD SPORT DC
    Ive been lurking around on TW for a while just stealing free advice and learning how to mod my tacoma. This thread saved my ass. I installed a pioneer 4300dvd and the metra aswc and couldnt get it to work properly. After messing with it all night i finally just decided to call it quits and went to bed. Metras website was no help. Lucky for me this fine group of tacoma owners had already solved my problem. Did a quick search, Found the wires i needed, and 20 mins later i was putting my dash together and everything was functional. Just wanted to say Thank you.
  20. Oct 29, 2011 at 7:30 PM
    #40
    jkisner2011
    jkisner2011 New Member
    Irwin
    11' Tacoma Access Cab
    Kenwood Dbl din Head Unit 5% window tint all around and 5% visor strip
    How do i connect the aswc to the tacoma factory plug?
