Need help installing Axxess ASWC steering wheel controller
Discussion in 'Audio & Video' started by trdracing5, Apr 10, 2011.
  1. Oct 30, 2011 at 6:31 AM
    #41
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    Woooooooooooooooo!!!!!!!!!!! I GOT MINE WORKING!!!!!!!!!
    I finally decided to tear mine apart again and mess with it(months later).....My issue was not having the white/red from the factory harness hooked up. I was thinking I had it grounded by having the black from the ASWC to the radio harness but I was wrong. As mentioned above the white/red from the factory harness NEEDS to be connected in with the other ground wires.
    Worked instantly!!!!
    THANK YOU EVERYONE!!!!
    Now if only I had a better option for the mounting kit.....I have single DIN Alpine and the Metra kit(from Crutchfield) and that thing is a total and complete POS. The plastic mount is so damn flimsy it's actually appalling!!! Oh well....some day I'll buy a double din and be able to use the factory metal mounts and lock it down tight.
    jgalvar likes this.
  2. Oct 30, 2011 at 8:24 AM
    #42
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Man, this was a complicated install for a noob like me. Thanks much for this post:
    I made these 4 connections, plus I used 2 taps and and extra piece of wire to connect the white w/red stripe wire (more like orange stripe, not completely red) to the black ground wire mentioned in step 1. Plus I was installing a Kenwood receiver so I had to use the brown wire on the 3.5mm adapter, and taped up the other adapter wire (brown w/white stripe). Switched on the ignition and it worked perfectly the first time.
    This thread, or at least a condensed version with the wire info, should absolutely be a sticky.
  3. Dec 4, 2011 at 12:35 PM
    #43
    takaya49
    takaya49 Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    #43
  4. Dec 4, 2011 at 1:00 PM
    #44
    Polymerhead
    Missouri
    No, that appears to be the dedicated Toyota harness. Mine came with about 20 wires and a confusing diagram on how to pick the right 2. Newer versions are coming with a simpler harness like what you have there.
    Here's a clue: the actual AXXESS unit should cost you about $60, not $9. ;)
    #44
  5. Dec 4, 2011 at 2:19 PM
    #45
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
  6. Dec 4, 2011 at 5:14 PM
    #46
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    #46
  7. Dec 20, 2011 at 8:28 PM
    #47
    The tacoman
    The tacoman Well-Known Member
    Texas
    2006 TRD
    Ok. So I have tackled this project myself, read through every thread I could find on this and searched the internet looked at the axxess site ect. I have my aswc hooked up like this.
    1) Black wire of the ASWC to ground using the same grounding point as the aftermarket radio.
    2) Red wire of the ASWC to a 12 volt accessory wire, one that turns on and off with the ignition key. Same as aftermarket radio.
    3) Connect the Green with Orange stripe wire of the ASWC to pin 7 (violet/white) of the vehicle.
    4) Connect the Black with Green stripe wire of the ASWC to pin 8 (yellow/black) of the vehicle.
    But when I turn it on and try to get it to program it blinks really fast at first and at one point it will turn the volume down a little bit on my head unit. After it flashes fast it pauses for the 2 seconds and flashes 7 times all short. Then pauses and flashes 6 times. I am using the Pioneer AVH-P4300DVD. Any help is greatly appreciated.
  8. Dec 21, 2011 at 4:24 AM
    #48
    double_b
    Red Lion, PA
    See my post above from 10/30/11...you NEED to have the white/red from the factory harness connected in with the other ground wires. Mine was doing exactly what you describe until I connected the white/red from the factory harness into the other ground wires. As soon as it did that it worked instantly.
  9. Jan 28, 2012 at 11:12 AM
    #49
    dsjacr
    dsjacr Active Member
    Scott
    West Monroe, Louisiana
    TRD Sport 4wd
    7" lift
    I am having issues with getting my access awed to control my 4300dvd. I have read all of the post and my wiring is correct. The red and white wire is grounded good with the radio. The led flashes and goes through the set up and then completes. The volume will beep during set up once. I am at a loss here.
  10. Jan 28, 2012 at 11:16 AM
    #50
    dsjacr
    Scott
    TRD Sport 4wd
    7" lift
    NVM LOL. I feel like an idiot! There is a orange and green wire and a green and orange coming from the assess. It will work if you wire it correctly! Dumb A** lol
  11. Jan 29, 2012 at 5:58 PM
    #51
    Nathan88
    Nathan88 Member
    Nathan
    Ga
    06 PreRunner SR5 TRD Sport
    DoubleDin Pioneer P3200 dvd headunit, Big Country chrome side step bars, 25% tint windows, Bak rollbak bed cover.
    I've had the same prob with mine as well but i will try the way described on this thread and see if anything changes.. why does this have to be such a pain in tha a$$??!!
  12. Apr 1, 2012 at 12:48 AM
    #52
    Tokeisch
    Tokeisch Active Member
    fLORIDA
    09 tACOMA pRERUNNER
  13. Apr 3, 2012 at 7:54 PM
    #53
    idgara007
    idgara007 Active Member
    tx/CA
    09 TRD Sport double cab
    Curious if this harness also works for the bluetooth controls on the right side of the steering wheel? I want an aftermarket headunit but dont want to lose the wheel controls (audio or bluetooth). If so, the new receiver should have bluetooth built in correct? Unless I want to shell out $$$ for a bluetooth adapter for the receiver right... I dont know jack about audio components obviously. Thank you very much for your help!
  14. Apr 3, 2012 at 8:48 PM
    #54
    Tokeisch
    fLORIDA
    09 tACOMA pRERUNNER
    It will work, you'll need a Bluetooth compatible HU. Go to axxess.com and check it out.
  15. Apr 3, 2012 at 8:50 PM
    #55
    Tokeisch
    fLORIDA
    09 tACOMA pRERUNNER
    Get the friggin harness. 7.99 w/ free shipping.
  16. Apr 3, 2012 at 8:53 PM
    #56
    Tokeisch
    fLORIDA
    09 tACOMA pRERUNNER
    If mine works I will post it "Barney style" ...not to confused with the other style....get your head out the gutter .
  17. Jul 8, 2012 at 8:36 AM
    #57
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have my Kenwood wired up like the above post say...with the exception that I cannot find a red/white wire in my harness. I have the black grounded to my radio ground. Light comes on and stays on but no workie.
    any suggestions?
  18. Jul 9, 2012 at 5:13 AM
    #58
    mne3312
    mne3312 Well-Known Member
    Alabama
    '10 Prerunner SR5
    K&N Air Filter, Weather Tech Floor Mats, Weather Tech Deflectors, Truck Covers USA Roll Cover, 15% front 5% back Tint, Toyota Hitch Cover, Pop & Lock 8521, Pioneer 4400BH, Infinity 6-1/2" Speakers, 4-Channel Amplifier, Access Bed Mat
    This is what I used for my Pioneer 4400. There are instructions for a Kenwood HU. I scratched through it bc I didn't need it, but you can still read it. I cannot find where I got it on the web so I just scanned it back in.
  19. Jul 9, 2012 at 10:33 AM
    #59
    paidfor
    Austin, TX
    2013 TRD OR 4x4
    I gave up on mine at 5pm yesterday. I disconnected the radio controls and put it back into the bag. Might tear it apart again down the road. So far I am in the hole on that purchase.:cool:
  20. Jul 22, 2012 at 8:17 AM
    #60
    Nathan88
    Nathan88 Member
    Nathan
    Ga
    I installed a harness that i ordered from *********.com , it's specifically for the tacoma, but when i had everything wired together and i turned the ignition switch on and as the controller was flashing i pressed volume up and down while it was programming and everything works just fine. Did you try pressing anything while it was self programming? If it still doesn't work, it might be the controller your trying to install. The one i ordered from ********* was pretty quick and easy
