Need help installing GMRS radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ReeceRiley, Jun 18, 2020.
  1. Jun 18, 2020 at 9:51 AM
    ReeceRiley
    ReeceRiley [OP] Well-Known Member
    Reece
    Des Moines iowa
    Tacoma in-line 4, 2 door, 5 speed
    I’ve got a 2008 regular cab manual sr5 and I want to install a GMRS radio. I want to the radio to the battery but have it turn off when I shut the truck off, could someone tell me where to run the wires to the engine bay and where to attach the wires to so that the radio shuts off when the car shuts off
  2. Jun 18, 2020 at 9:54 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Simple: use an add a circuit off of your fuse block on a switched circuit.
    Even better: do the above to trigger a relay powered from the battery to power the radio.
    How many watts is your radio? I just purchased the Midland MXT275 for me and my dad. The higher the wattage the less ideal the simple solution is.
  3. Jun 18, 2020 at 9:58 AM
    ReeceRiley
    Reece
    Des Moines iowa
  4. Jun 18, 2020 at 10:02 AM
    ReeceRiley
    Reece
    Des Moines iowa
    What is an add a circuit
  5. Jun 18, 2020 at 11:13 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  6. Jun 18, 2020 at 11:17 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    So the add-a-circuit thing is fine but I wouldn’t run that as my power source. What you can do is set it up as a relayed 12v line from the battery, using an ignition only circuit as your trigger for said relay.
    but ideally you should run power straight to battery and ground to either battery or nearest body ground and leave it at that and make sure to just turn it off when truck is off. It also makes it so you can turn the radio on and use it real quick if the truck is off, rather than have to turn the engine on.
  7. Jun 18, 2020 at 11:20 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I run my MXT 400 right to the battery. It's 40 watts. Just remember to turn it off.
    NTX.TACOTRUK and 4x4cajun like this.
  8. Jun 18, 2020 at 5:47 PM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
  9. Jun 18, 2020 at 7:04 PM
    rednext
    rednext Well-Known Member
    I have run 2-way radios in my trucks for years on the farm and the only way it'll kill the battery is if you leave it on for a week straight (and there's lots of traffic on the radio at the same time). If you use your truck daily, or every other day, you'll be fine. Or just turn the radio off when leaving. I tend to agree that it needs to be run straight to the battery with an inline fuse
  10. Jun 18, 2020 at 7:08 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Careful. Those more power gmrs radios can pull 25amps +. Those cigarette outlets have a 10 or 15 amp source
  11. Jun 18, 2020 at 7:57 PM
    Old Swamper
    Will
    Northern WI.
    5100 & OME 884 AAL
    His model is a 15 watt one.
    m603holden[QUOTED] likes this.
  12. Jun 18, 2020 at 8:00 PM
    ReeceRiley
    Reece
    Des Moines iowa
    I set it up today, I rain it straight off the battery. The radio it self is under the drivers seat
  13. Jun 18, 2020 at 8:00 PM
    ReeceRiley
    Reece
    Des Moines iowa
    I’ll have pictures tomorrow
  14. Jun 18, 2020 at 8:05 PM
    Myrtle Beach Taco
    Myrtle Beach Taco Member
    Myrtle Beach
    12 currently stock
    You should actually run an inline fuse on both the positive and the negative line. That is the way a lot of mobile devices in hamreadio are wired.
  15. Jun 19, 2020 at 2:49 AM
    m603holden
    Marteeen
    New England
    Indeed. I was referring to yours. Was just putting it out there. Didn't know if you had the 50w version. Seems you know the deal though.
    Old Swamper[QUOTED] likes this.
  16. Jun 19, 2020 at 6:31 AM
    DG92071
    DG92071 Well-Known Member
    The amount if current that your radio draws is extremely small. A relay is definitely not required. An add a circuit is fine.
    The amplifier section of your radio uses 1.25 amps at 12 volts, the rest of its power consumption is lights for its display.
  17. Jun 19, 2020 at 6:44 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    If you are not comfortable constructing your own relay:
    https://powerwerx.com/automotive-dc-timer-lvd-battery-guard
    Not the cheapest, but easy and cheap are usually mutually exclusive.
    I'm not up on GMRS rigs, but lots of ham rigs have auto power off settings. Remember, if you make a key-on relay and you want to use your radio while stationary, your truck will be chiming the whole time your door is open. That's sub optimal.
  18. Jun 19, 2020 at 7:17 AM
    m603holden
    Marteeen
    New England
    @ReeceRiley
    I mean I probably wouldn't do any of that. If you want to use your radio when the truck is off, you'd have no option.
    Which you will use the radio when the truck is off. Just how it is.
  19. Jun 19, 2020 at 7:39 AM
    DG92071
