Need help installing Metra TYIP-01 Ipod adapter
Discussion in 'Audio & Video' started by rolltide3705, Sep 18, 2010.
  1. Sep 18, 2010 at 3:37 PM
    rolltide3705
    rolltide3705 [OP] Well-Known Member
    A.J.
    Birmingham, Alabama
    06 Prerunner Sport Double Cab
    Just got my Metra TYIP-01 ipod adapter from metra. I went to install it and cannot seem to get it to work. the male plug goes into the open slot in the back of the radio but it doesnt click/lock into place. Then there is a female plug that I dont know where to put. I tried with just the male plug in and it would not work. I included some pictures, so maybe someone can help me out. These pics are taken from behind the radio on the dash side looking back into the cab.
    Thanks, A.J.
  2. Sep 18, 2010 at 4:05 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    also, forgot to add, when I plugged it in to test it, it said accessory connected on my Ipod but would not play through the stereo.
  3. Sep 18, 2010 at 4:14 PM
    Shiftin2Sixth
    Shiftin2Sixth Well-Known Member
    Curt (kûrt)
    Southern California
    2021 MGM TRD-OR DCSB 4WD
    I dont think you use the female plug unless you have a external CD changer. Everything else you say sound like its hooked up right. Hit the CD button on the radio twice to change it from CD to iPod
  4. Sep 18, 2010 at 4:19 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    ok ill try it again and see if it workds
  5. Sep 18, 2010 at 4:46 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Just tried it again. It says on the ipod screen that it is connected but when i push disc it just stays on the CD thats playing. One thing that worries me is that the plug will not click into place.
  6. Sep 18, 2010 at 5:47 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Bump. Nobody?
  7. Sep 18, 2010 at 8:07 PM
    MSUtacoboy
    MSUtacoboy Well-Known Member
    MS
    2008 Silver DC 4x4 Trd off-road
    mine did not click into place either. i don't know why it's not working if the ipod is showing it's connected. hitting disc twice should show CD1 on the radio as if it was a changer and you're on disc 1.
    sorry, i was no help
  8. Sep 18, 2010 at 9:10 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    I tried it again and it worked then i turned the truck off and back onand it didnt work. Looks like ill be working on it some more tomorrow. But thanks for the input.
  9. Sep 19, 2010 at 2:07 PM
    MSUtacoboy
    MS
    could be a lose wire. or lose connection.
  10. Sep 19, 2010 at 3:12 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    ya I dont know what it was but I got home from church this morning I tried it one more time and it now works. Ran the wire through the cubby to the right of the steering wheel and couldnt be happier.
  11. Sep 19, 2010 at 9:00 PM
    tucker11
    tucker11 New Member
    I have the same Metra TYIP-01 ipod adapter from metra and could not get mine to work do you have the JBL Radio?
    what did you do with the small male plug.
  12. Sep 20, 2010 at 3:38 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    I dont have the jbl. The male plug should go in he only open slot in the back of the radio. The female plug doesnt plug into anything. Make sure the black 3.5mm chord, which is on the left side of the radio is plugged in when you test it. I think that might have had something to do with it not working. The male plug will not click into place but just push as hard as you can on it and it should stay.
  13. Feb 11, 2011 at 10:20 PM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    hey rolltide, does the TYIP-01 also have an aux input? been reading sites and most only talk about iPod input. i want to play from my other .mp3 players including blackberry that has a standard aux out.
