NEED HELP ON BATTERY?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, Oct 17, 2011.
  1. Oct 17, 2011 at 1:45 PM
    bluebeast
    bluebeast [OP] Active Member
    06 bluebeast
    smitty bulls bar procomp 3in lift westin nerf bars
    i have a 06 tacoma that is lifted. ever since the lift my battery keeps leaking out the acid because the truck is pretty stiff, so when i hit bump or uneven street, i believe this cause the acid in the battery to splash and leak out on top of the battery causing. I heard that the only battery that will help is the optimal battery but it cost a grip. any suggestion? thanks
  2. Oct 17, 2011 at 1:47 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    there are alot more closed no maintenance batteries out there that isnt an optima... i know the factory battery has no fill holes that could leak
  3. Oct 17, 2011 at 1:56 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Optima is one of the most expensive batteries on the market.
    You can get much cheaper ones that won't leak (Diehard, NAPA, etc.).
    Fink
