need help on what to do about dealer putting dent in my bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danmckennat, Apr 25, 2009.
  1. Apr 25, 2009 at 2:40 PM
    danmckennat
    danmckennat [OP] Well-Known Member
    chardon, ohio
    2009 tacoma access cab offroad package
    sorry this is kind of long. ok so i took my truck which is only 6 months old to dealer other day to get my bed realigned. i washed truck right before i took it to check it for dents or scratches. well when i got the truck back i found two dents in front of the gas door. with that said i complained to manager and they had the dent guy try to remove them. well the dents are mostly out but the paint is like wavey. you can still tell where the dents used to be. they told me they could repaint the one side of the bed for me to try and fix it. so here is my worry. my truck is silver and i hear silver is one of the hardest colors to match because of the silver flake that is in the paint. i took it to a few body shop guys and they said that they would not have it repainted because silver is so hard to match and that the guys at toyota really dont know what there doing becuase they couldnt move a bed over without putting dents in it. they told me just try to get something else out of toyota like some accessory. what should i do?
  2. Apr 25, 2009 at 2:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would make them fix it. If it wasnt there when you brought it in, they need to put it back in that condition. If it means they have to PERFECTLY match the paint one way or another, so be it.
  3. Apr 25, 2009 at 3:28 PM
    Jester182
    Jester182 Well-Known Member
    SoCal
    08' Taco SR5 Double Cab - Indigo Ink
    Single-din Sony Xplod, SnugTop SL, AFE Pro Dry
    Ditto. They are fully responsible for what happened on your truck, I say you have them fix it, and if they give you crap just move on up to management until you get results.
  4. Apr 25, 2009 at 3:39 PM
    JTech
    JTech Well-Known Member
    Phoenix, Arizona
    Silver 09 Double Cab 4x4 Sr5 Off-Road
    Locking Bed Boxes, built in air compressor, Husky Liners(not really a mod but I love them)
    I would definitely make them fix it correctly. When my toyota dealer scratched up my interior panels and steering wheel I made them replace it all. it ended up costing them over 2 grand in parts but whatever they screwed up. It will be a fight but it is worth it.
  5. Apr 25, 2009 at 3:41 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    It even harder to match the older pain that has been subjected to weather. If i wanted it to look good I'd rather them paint the whole thing
  6. Apr 25, 2009 at 3:52 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    To me it kinda depends on now noticeable the dent is, and how important it is to you to have it fixed. If the dent is really going to be bugging you, fight with them until the fix it right. If you can live with the minor dent, and don't want to keep fighting with them, I say try to get some kind of accessory out of them.
    My personal attitude about the truck, is that it's a truck, and I expect it to sustain some kind of body damage at some point throughout (not that I WANT it to happen). As long as the paint was fine, and wasn't too noticeable, I'd go for some kind of accessory.
  7. Apr 25, 2009 at 4:02 PM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    IMHO having it painted is a bad idea... just seems like there's more potential for messing up a paint job... overspray, bad taping, reacting to sunlight differently than the factory paint... etc, etc. I'd probably see if they'd give you some kind of accessories, or even better, an extended warranty that includes paint defects should the paint on those fixed dents peel off in 2012!
    Just make sure your complaint about the 'wavy' paint makes it into the service records in case it gets worse later on they can't deny blame.
  8. Apr 25, 2009 at 6:51 PM
    danmckennat
    chardon, ohio
    yea the dents are mostly out. you really have to stand in front of or behind the truck to see them. you cant see them standing at the side. i am just worried if they try painting it they are just going to make problem worse or screw something up even more. i heard you really dont want to remove the factory paint.
  9. Apr 25, 2009 at 7:57 PM
    cleanTRDmachine
    cleanTRDmachine watch the meat
    Kyle
    Q-Town, PA
    06 DC TRD
    tint gray camo seat covers debadged color matched grille surround off of 06 TRD sport grillecraft black mesh grille Hella 500's demudflapped Toyota rear leaf TSB (first edition) 265/75/16 BFG AT TA KO's Flowmaster Super 40 #952445 Maglite Mod AntennaX 13in antenna Painted Lower Valance Vision X H4 Xenon headlights Halo Solaris H10 foglights Velocity Offroad 2.5 leveling kit (removed) Spidertrax 1.25" wheel spacers Rocky Mounts Clutch SD bike mount 4ft combo lock cable for bed extender Stage I interior LED's Toytec 1.5" AALs Extang Trifold Signature Series Bed Cover Reese front mounted tow hook Icon Stage 1 Suspension
    make them give you a new truck
  10. Apr 26, 2009 at 6:01 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    +1 pick your battles. It's your truck, you need to be satisfied. I've seen body shops do a great job matching paint. I think it's mostly the talent/ability of the shop. I spun my prelude down a hill bouncing off guard rails on ice. Took it to a local shop and I'll bet NO ONE would be able to tell it had bodywork done.
    I wouldn't let the fear of the paint not matching hold you back.
