Need help quick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skadumz, Apr 13, 2012.
  1. Apr 13, 2012 at 4:38 PM
    Skadumz
    Skadumz [OP] Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    Replacing new front diff seal. I know I am an idiot but how far does the seal
    Go in the diff
  2. Apr 13, 2012 at 4:49 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I really want to help you, but your question is just too vague.
    Are you talking about the front diff drain plug gasket? fill plug gasket? one of the axle seals?? You pulled and disassembled the whole thing and you're talking about the pinion bearing seal???
  3. Apr 13, 2012 at 4:52 PM
    Skadumz
    Lehigh Valley, PA
    Sorry about the lack of info but thanks for replying. It is the seal where the cv axel goes into the front diff driverside.
  4. Apr 13, 2012 at 5:11 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  5. Apr 13, 2012 at 5:17 PM
    Skadumz
    Lehigh Valley, PA
    Sorry not really I think my problem to begin with was it was in too far so the seal did t completely wrap the axle. It would only leak when turning or pushing it in the diff and pulling back out
  6. Apr 13, 2012 at 5:33 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As from the factory? Or had you or someone else previously replaced it?
    If so, any chance the seal was installed backwards?
    There's a good diagram on the FSM page that I linked.
    Aside from this stuff, I got nothing. Maybe someone who's installed the seal itself will chime in.
  7. Apr 13, 2012 at 6:00 PM
    Skadumz
    Lehigh Valley, PA
    I really appriciate the response. And yes last weekend we replaced needle bearing with a bushing from ECGS. As well as the cv axel. Drives so much smoother no vibes but the seal leaked so I got a new one today and did some measurements of cvaxel and diff housing and it seemed we put seal in to far. That if the cv axel work pull away from the diff with its usual play it would be out of the seal and that is the only time it would leak.
