Need help replacing all 4 ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bruno, Jun 20, 2012.
  1. Jun 20, 2012 at 1:53 PM
    Bruno
    Bruno [OP] Well-Known Member
    Bruno
    1996 4x4 V6 Xtra Cab 5spd
    1st Gen Fabtech Coilovers, Rear Add a Leaf, 33x12.5 BFG Mud Terrains, Deck Plate Mod
    Bought 4 moog BJs.
    Have truck on jack, wheel off.
    I've removed the nut holding the upper BJ to the UCA.
    Took off the upper BJ boot.
    I'm cranking the BJ separator between the spindle and UCA, it won't budge.
    I've hit the upper BJ with a hammer, can't get it out.
    Need suggestions under car typing with phone ;)
  2. Jun 20, 2012 at 2:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Diode Dynanics SS3 Sport Selective Yellow Fog Lights 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yeah, the uppers are a bitch. I ended up removing the whole spindle/knuckle and having a shop press them out. At the very least you'll need some sort of bj press tool to get them outa the top of the spindle and to press the new ones back in.
  3. Jun 20, 2012 at 2:11 PM
    white toy taco
    white toy taco 505 Member
    Gian
    Albuquerque, NM
    02 4X4 Taco SR5 TRD V6
    All-Pro tube bumper, 5100's at middle setting w/OME 881's, rebuilt leafs w/ 2 chevy leafs, 265/75/16 Km2's, CloudyFab sliders, 6000k HID headlights (35w), 16" LED light bar,100w KC Daylighters,
    if you go to autozone, you can get balljoint/tie rod end removers. they look like a big "U" with a bolt running down the middle. attatch a large wrench to the bolt and it will pop right out. trust me this is the easiest way\
    EDIT: actually now that i took a better look at Digi's picture above, its the same concept
  4. Jun 20, 2012 at 2:14 PM
    Bruno
    Bruno
    How did you get the spindle off the UCA? I'll take em to a shop to press the new ones in but as of now I can't separate them. Did u take the spindle off the LCA before you disconnected the spindle from the UCA?
  5. Jun 20, 2012 at 2:16 PM
    Bruno
    Bruno
    What brand puller remover is it? Got two pullers from Oreilly and neither fit.
  6. Jun 20, 2012 at 2:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
  7. Jun 20, 2012 at 2:33 PM
    Bruno
    Bruno
  8. Jun 20, 2012 at 3:47 PM
    Bruno
    Bruno
    FU€£!!!
    It's not budging. I had a puller on it like the one above and cranked as hard as I could until the pulled warps and slips off. Other option is to try the ball joint separator with like a 6 foot breaker bar over the end.
    I'm at a loss. Now I'm thinking of removing the UCA and taking both pieces to the shop for replacement. This is pissing me off. Open to suggestions. Can't even drive it now. Brutal.
  9. Jun 20, 2012 at 4:27 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    have you tried putting the bj in a vice and using the bits? may be able to control things better and get more oomph on it? Did you take out the snap ring holding the upper on?
  10. Jun 20, 2012 at 4:40 PM
    Bruno
    Bruno
    Haven't gotten there yet...
    BUT, I just managed to get the ball joint out of the UCA...I used a 4 ft extension over the BJ separator.
    Now onto removing the BJ from the spindle....sigh...
  11. Jun 20, 2012 at 5:56 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
  12. Jun 20, 2012 at 7:12 PM
    Bruno
    Bruno
  13. Jun 20, 2012 at 7:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Pitman arm tool for the UCA and LCA balljoints.
    Balljoint tool for the tie rods. :D
  14. Jun 20, 2012 at 9:56 PM
    white toy taco
    Gian
    Albuquerque, NM
    this is exctly what i used. it worked like a charm
  15. Jun 21, 2012 at 12:10 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Kinda late chiming in here & all good suggetions, now this is what to do to remove, get a hammer, a big hammer (stay with me here it aint a joke ) Now Smack the spindle around where the ball joint goes in a few times HARD !!! Dont try to "aim for the cheap seats hard ", but hit it with authority, since you're changing ball joints anyway hit the top of it now,
    look down, it is now seperated... You DID remember to remove C clips right ??
  16. Jun 21, 2012 at 12:16 AM
    Manwithoutaplan
    ID
    how much are these tools typically??
  17. Jun 21, 2012 at 4:35 AM
    bb609
    bb609 O.F.
    NH
    I used it on my upper but it is pretty versatile. I don't see why it wouldn't work on both.
  18. Jun 21, 2012 at 7:14 AM
    white toy taco
    Gian
    Albuquerque, NM
    i think the top one is like $15-$20 and i would assume that the other one would be around the same. not too expensive
  19. Jun 21, 2012 at 7:47 AM
    Bruno
    Bruno
    So far I've used a standard ball joint separator "fork" with a 3-4ft extension on it. That has popped both the upper and lower BJs. Then I used a pitman arm tool for the tie rod.
    I've installed the MOOG lower BJ and this morning I'm going to try and press out the upper BJ from the spindle and replace it with a MOOG. If I can't get it, Im gonna take the spindle to a shop.
    This is all for the right side. Then its onto the left...which I'm sure will get done in a 1/4 the time.
  20. Jun 21, 2012 at 9:48 AM
    Bruno
    Bruno
    So fucking sick of this shit.
    I tried every combo I had of 2 pitman puller tools, a ball joint remover/installer (looks like a C Clamp), and a bunch of other ways. I can't get the upper ball joint out of the spindle.
    And to top things off, I get down and check out the lower MOOG BJ this morning only to find two tiny tears in the boot.
    What a fucking mistake this was. Gonna have to take the spindle into a shop. FUCK!!!!
    Pardon the french.
