Need Help! Wiring Harness pins do not fit
Discussion in 'Audio & Video' started by sdheda, Jul 25, 2010.
  1. Jul 25, 2010 at 9:52 AM
    sdheda
    sdheda [OP] Well-Known Member
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    I bought a Scosche TA02B wiring harness, and I already soldered my connections and everything. Now when I take my stock headunit out, and try to plug in the wiring harness, none of the plug can fit???
    Did I buy the wrong wiring harness? This wiring hardness was suggested by other members here, which is why I bought it.
    BTW, I have the JBL 6 speaker system, if that makes a difference.
  2. Jul 25, 2010 at 10:04 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If you have the JBL system then per Scosche's website you have the wrong wiring harness.
  3. Jul 25, 2010 at 11:14 AM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    It does not seem as though I had done enough research about this ahead of time.
    Searching now specifically for the JBL wiring harness, it seems like I would have to buy a $70 wiring harness which will then connect to the JBL amp. This seems like a waste, since I wanted to use the headunit to power the speakers. There is a wiring harness that can bypass the amp, but then I would have to run it all the way to the rear.
    Maybe I should just get a new amp instead.
  4. Jul 25, 2010 at 12:40 PM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
  5. Jul 25, 2010 at 8:29 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Could you run speaker wires fromthe HU to the individual speakers? That would bypass the amp. I think that expensive harness is used if you want to use the JBL amp with the new HU. Not if you want to bypass.
  6. Jul 25, 2010 at 9:25 PM
    sagebum
    sagebum Well-Known Member
    James
    Elk Grove (NorCal)
    07 DC 4x4 TRD OR white
    -- This is if you would like to use the existing JBL amp to power your speakers.
    rb11701 is correct - If you'd like to use the new Headunit to power your speakers, you would have to run speaker wire directly to them(bypass the jbl amp), or option 2 - purchase the "bypass" harness (also around 60$) that's available that will using the JBL speaker wiring, but rather than having to run speaker wire to 4 speakers, you would just run the speaker wire to the JBL harness (located at the right side rear by the jbl amp/sub).
