need HELP wiring head unit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by schiz94, Jun 20, 2010.
  1. Jun 20, 2010 at 6:43 PM
    schiz94
    schiz94 [OP] Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    ok. so im done wiring. now this fucking metra kit is pissing me off. i cant figure out how this is held in the dash.
  2. Jun 20, 2010 at 7:00 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    it just pops in with 4 tab things, you may have to do a little sanding/fine adjusting to the kit to make it sit well in the dash. You get a single or DD?
  3. Jun 20, 2010 at 7:31 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You don't have to re wire anything if you remove the head unit again. It all should be plug and play. The HU harness should match up to the Crutchfield harness that plugs into the OEM plugs. All you are doing is using the factory ground. The colors should just match up. It's an industry standard.
  4. Jun 20, 2010 at 7:33 PM
    snowgod06
    Rob
    06 Access Cab
    the ground that came on the stereo has a hook attachment on it. Which unless he has the parts handy to attach it to the harness, its easier now and in the long run to just ground it to a bolt.
  5. Jun 20, 2010 at 7:44 PM
    dexterdog
    Oly WA
    2012 F150
    He has to connect the rest of the wires, the ground is no different. Cut and splice. It's a pain in the but to pull out the head unit and unscrew the bolt that you decide to use instead of trusting the factory ground.
  6. Jun 20, 2010 at 8:02 PM
    snowgod06
    Rob
    06 Access Cab
    Thats what im talking about being a pain in the future. If he cuts and splices the ground then if he takes the radio out again, he's going to have to splice it back together again. Im not trying to be a prick, im just saying in the long run its way easier to just ground to a bolt vs. splicing it.
  7. Jun 20, 2010 at 8:40 PM
    dexterdog
    Oly WA
    2012 F150
    All you have to do is unplug the harness. There is no cutting and re splicing if you wire the hu harness to the wiring kit that plugs into the factory harness.
  8. Jun 20, 2010 at 9:18 PM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    too late. i did was snowgod said and it works :) im happpy.
  9. Jun 21, 2010 at 7:02 AM
    snowgod06
    Rob
    06 Access Cab
    looks good man, good work!
  10. Jun 21, 2010 at 7:09 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    the ground is part of the stock wiring harness, just like the hot wire and the speaker wires. its much easier to wire the crutchfield harness into the vehicle harness so that it all becomes plug and play.
