Need help wiring the third brake light on a Bestop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco, Jul 18, 2009.
  1. Jan 20, 2014 at 11:20 AM
    NordicWolfman
    NordicWolfman New Member
    Jeff
    40.5592° N, 105.0781° W (Colorado)
    Tacoma DCLB TRD
    Installed the Supertop on my 2014 DCLB yesterday and installed the 3rd brake light today. I decided to add/reinforce what is in this thread. A few notes:
    -The extra light is chintzy, as stated. Mounting mine to to bow was annoying. One of the screws passed right through the plastic. I kept tinkering and eventually got it to stay. It is fairly solid and after a little more time got it fairly level.
    -I ran the wires to the driver's side and slipped them under the lining into the taillight inset (there was a small natural opening). I did my best to route the wires and secure them, but it still looks a bit cheap having exposed wires-- oh well; for now. I only ran the two I needed.
    -I removed the driver's side taillight and found the green/red and black/white wires from the truck. I previously tested (9V battery) the 3rd light's wiring and found (black= (-), yellow= (+)solid light, red= (+)strobing light-- apparently they just use whatever wires are available). I spliced into the wires as described above (for me= black to black/white; yellow to green/red) and tested. It lit up only when I pressed the brake (I tested the headlights, parking lamp, turn signals, etc and these did not activate the light). Success.
    -The wires on the 3rd light were not long enough to be attached once reinstalled so I had to extend the wires (on the 3rd light) and then made the splices (semi-)permanent with solder and electrical tape at all connections. I debated soldering but considering I had to lengthen the wires and had that 120V outlet on the bed of the truck just waiting to be used...I spent the extra 10 minutes.
    -I put everything back together and the light at least looks good and works!
  2. Jan 8, 2017 at 1:54 PM
    Adam16
    Adam16 Member
    Adam
    Nova Scotia
    13 Black Tacoma Turd
    Bed mat Hood deflector 3D Maxpider floor mats (front only) Car seat mod x2 Blacked out badges Leer topper
    Can soneone clarify for me...the 3rd brake light only works when the brake is pressed...right?
    R61988 likes this.
