Need Help with Alternating turn signal
Discussion in 'Lighting' started by 2000GTacoma, Jul 14, 2012.
  1. Jul 14, 2012 at 7:38 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I just installed lights in the grille of my 1st gen 2000 tacoma. I want the raptor light mod which is what I am working on. Now what I would like to do is have the left side grille light alternate with the turn signals and have alternating turn signals. I also want all 3 grille lights to act as marker light until I hit my turn signal. Then outside light alternates with the turn signal. The problem I have with using the alternating turn signal method is it only works with the marker lights on if I am reading this correctly. What I am looking for it the outside lights on the grille to alternate regardless if the marker lights are on or not.
  2. Jul 14, 2012 at 7:52 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    13 MGM Tacoma DCSB
    None, yet
    I'm not too sure how you have your raptor style lights set up. I am no electrical engineer, bu what would make sense to me is to...
    1. have your raptor lights wired so they are like the switchback mod
    OR
    2. somehow manage 2 hot wires into the LEDs. (insert electrical engineer here)
  3. Jul 14, 2012 at 7:54 PM
    2000GTacoma
    Snow Hill NC
    as of right now they are just in the grille so i have a hot and ground wire for each of the 3 lights.
  4. Jul 14, 2012 at 8:29 PM
    2000GTacoma
    Snow Hill NC
    basically i want the alternating turn signal mod to work regardless if my marker lights are on or not
  5. Jul 15, 2012 at 6:47 AM
    2000GTacoma
    Snow Hill NC
    morning bump
  6. Jul 15, 2012 at 9:01 AM
    2000GTacoma
    Snow Hill NC
    lunch bump
  7. Jan 8, 2014 at 9:23 PM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    i want to do something similar. what we need to do is add another relay to give power to the other relay that does the alternating blinking. Basically giving the light power as long as the turn signal switch is activated. Only problem is I don't know where to draw this power from. As I understand it, we need this power from before the blinking module, wherever that is...
    Thoughts?
