Need help with bed light installation
Discussion in 'Lighting' started by MarmotMountain, Apr 18, 2019.
  1. Apr 18, 2019 at 9:05 PM
    MarmotMountain
    MarmotMountain [OP] Active Member
    Bellevue, WA
    2017 Inferno TRDOR DCSB
    Hi all,
    I'm in need of some technical help! I spent the whole day getting my bed lights installed and wired, but at the end of the day, something is wrong and isn't working properly.
    I followed Tullie D's electrical diagram for the most part (see attached). I did, however, attach my RED 2 to my dash light via add-a-circuit. Which the CH4x4 doesn't light up as well.
    These are the components I used:
    Autuneer LED lights
    Wire 12 gauge
    Heat shrink
    Absolute relay
    CH4x4 push switch
    Using a multimeter, I can verify that the relay is working. Despite that, the CH4x4 is not lighting up and does not work when I press the button. I'm not sure how to trouble shoot this or even where to start troubleshooting. If anyone has any ideas that would be greatly appreciated.
    chiefjim likes this.
  2. Apr 19, 2019 at 4:14 AM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
    Did you test to.see if you have power at the switch?
  3. Apr 19, 2019 at 7:13 AM
    MarmotMountain
    Bellevue, WA
    Hey Rd62, thanks for responding. I just used my multimeter, I'm getting no power at the switch despite having power at the relay? (My wire attaching to blue on relay is heat shrinked to the same junction as the wire going to my green on the CH4x4).
  4. Apr 19, 2019 at 8:31 AM
    Rd62
    2014 DCLB TRD Sport
    Looks like its wired correctly according to the diagram (though I'd tie red 2 into a dash illumination circuit). Have you checked your connections where you tied switch power into the feed off the battery and where that is tied into the switch harness?
  5. Apr 19, 2019 at 1:13 PM
    MarmotMountain
    Bellevue, WA
    I ended up cutting the cord that attaches to my green. I can verify that the power source is working via my multimeter.
    I actually did stray from the original diagram and used an add-a-circuit to attach my Red 2 to my dash lights (tail light). Nothing will illuminate. I'm no engineer but I'm hoping that it's the CH4x4. I just contacted them to see if they can help out.
  6. Apr 19, 2019 at 1:21 PM
    Rd62
    2014 DCLB TRD Sport
    You got a different switch you can hook up to verify? If not, I'd hit the Autoparts store and pick one up just to trouble shoot.
  7. Apr 19, 2019 at 1:34 PM
    MarmotMountain
    Bellevue, WA
    Sadly I don't. Everything is also shrink wrapped so I'd prefer not to take all my hard work apart too. However, if that's the easiest way to troubleshoot, I'm all ears.
  8. Apr 19, 2019 at 2:16 PM
    Rd62
    2014 DCLB TRD Sport
    Well, it's pretty basic. If you have power to the switch and not to the relay then either the switch is bad or you have a poor connection between it and the relay. I hear ya on not wanting to mess with the shrink wrap, etc but sometimes ya gotta do what ya gotta do. I'm just speaking for me, but I'd try another switch to verify.
  9. Apr 19, 2019 at 2:57 PM
    MarmotMountain
    Bellevue, WA
    Thank you! I plan on going that direction first - trying a new switch.
  10. Apr 19, 2019 at 2:58 PM
    caribe makaira
    Caribbean, Puerto Rico
  11. Apr 19, 2019 at 3:05 PM
    MarmotMountain
    Bellevue, WA
    Hey caribe, I should've clarified. Instead of following the diagram, I attempted to attach my RED 2 to my dash lights via add-a-circuit. Even with my headlights on, it didn't illuminate the CH4x4 switch.
  12. Apr 19, 2019 at 3:07 PM
    caribe makaira
    Which fuse did you specifically tapped for the "add-a-circuit"?
  13. Apr 19, 2019 at 3:09 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    On the add a circuit did you use two fuses of the same amperage in it?
  14. Apr 19, 2019 at 3:14 PM
    MarmotMountain
    Bellevue, WA
    Nope - original "tail light" was 7.5amp. I used 3amp for my add-a-circuit.
  15. Apr 19, 2019 at 3:14 PM
    MarmotMountain
    Bellevue, WA
    The "tail light".
  16. Apr 19, 2019 at 3:16 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Get 2 7.5A fuses and make sure they are both in the add a circuit.
  17. Apr 19, 2019 at 3:30 PM
    caribe makaira
    Maybe the switch is bad...
  18. Apr 19, 2019 at 3:33 PM
    caribe makaira
    Relay actuation juice is less than .5 amps, why would matching the tapped circuit require same fuse amps?o_O
  19. Apr 19, 2019 at 3:47 PM
    caribe makaira
    In case others want to add to TAIL circuit, the PANEL is in parallel with TAIL using same TAIL relay.
  20. Apr 19, 2019 at 3:48 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I'm no electrician. What I can tell you is that last weekend when installing my ARB fridge monitor I placed one fuse in the tap and left the other spot blank and wouldn't get juice to the monitor. When I added a second fuse, it worked.
