Need Help with brake Controller Harness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport2010, Jun 30, 2010.
  1. Jun 30, 2010 at 2:50 PM
    TRDsport2010
    TRDsport2010 [OP] Grease Monkey
    Corey
    Houston, Texas
    2010 Silver TRD Sport
    OK guys im stumped. I have a 2010 tacoma prerunner trd sport with the tow package. Everyone, including my owners manual is saying that the trailer brake controller harness is located on the drivers side kick panel. I have been looking for it for about an hour now in my shop and for the life of me I can not find it. Have they moved it on the 2010 or is it hidden? I have been under the kick panel a few times before to hook up other stuff and havent ever seen anything similar to this connector. Anyone run into this before?:confused:
    Thanks
  2. Jun 30, 2010 at 3:32 PM
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    Just did mine a month ago on a 2009 Sport. The pigtail was supplied by Toyota and in the glovebox. The plug that the pigtail plugs into was located DEEP up under the dash on the far left of the drivers side foot well, not behind the kick panel. Being that I bought the truck used I was lucky to have the Toyota pig tail but did not have the wiring diagram with it, so I pluged it in and manually checked the circuits with a 12 volt tester and compared the results to my controller requirements. You might be able to get a wiring diagram online or already have one from Toyota. Bear in mind also your controller requirements might be different from mine. My hook up was really not that hard though, there was only fused hot, ground and brake actuation into my controller and one wire out to my trailer brakes for a total of 4 all contained in the Yota harness. Also for some reason (and the only wire that was labelled by Toyota on the supplied harness) there was an extra lead for the trailer brake lights but I did not use it or need it as there was no place to connect it on my controller and apparently the factory trailer plug harness takes care of the brake lights already (I'm guessing because most don't use trailer brakes). Hope it all makes sense and sorry I dont have any pics but could take some of mine if you need. I would'nt think 2009 is different from 2010 but not sure.
    Good luck!
    And if anyone knows the reason for the extra trailer light wire on the Toyota harness I would love to know why it's there or how it might be used!
  3. Jun 30, 2010 at 3:49 PM
    TRDsport2010
    Corey
    Houston, Texas
    Thanks! Found it! It was right in front of my face! duhhhh behind the huge ball of wires off the main harnes
  4. Jun 30, 2010 at 8:04 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Just made a PDF of the instructions that came with my 2010, see attached.
  5. Jul 1, 2010 at 3:19 AM
    cobrakenny
    Ken
    Raleigh, NC
    Thank You Mark, just printed that for my Taco folder.
    I see now the rogue wire is for "trail" lights not tail lights as I thought but I still don't get what it would be used for. Maybe to signal someone from behind while towing?
    But it it comes off the headlight then you would flashing your lights up front at the same time!?
  6. Jul 1, 2010 at 5:48 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Thanks for posting that PDF. Would you be able to tell me what colour wires are in the mating connector (ie. in the truck harness)? I found a 5-pin connector and the colours don't match those on the PDF.
  7. Jul 2, 2010 at 4:56 AM
    megillet
    Mark
    Atlanta, GA
    Someone else might be able to help with that, I haven't had the need to take off my kick panel and use this yet.
