Need help with my lift!!!
Discussion in '5 Lug' started by TRDChris, Jan 29, 2012.
  1. Jan 29, 2012 at 5:31 PM
    TRDChris
    TRDChris [OP] Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
    So I just installed the 3 inch fabtech spindle lift in the front and the fabtech shackles in the rear of my 2001 toyota tacoma and now my brake pedal sinks all the way to the bottom as if it has no pressure although it does. my truck does brake, but why is the pedal sink all the way to the bottom as if it were my master cylinder but it's not? Can Anyone give me some insight on this matter I'm stuck
  2. Jan 29, 2012 at 6:27 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    Does this lift kit include longer brake lines that you had to install? If it does you might want to try bleeding the brakes.
  3. Jan 29, 2012 at 10:33 PM
    TRDChris
    La Puente
    5 lugger
    It doesn't include longer brake lines just brackets to extend the brake lines 2 inches higher. I bled the brakes and even then my pedal just sinks to the bottom. My brakes are working but my pedal is what is worrying me? I don't understand why it has no pressure?
  4. Jan 30, 2012 at 12:22 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Did you fill the reservoir back up after bleeding them?
    It shouldn't have been necessary to even bleed them... When I did mine I just zip tied the calipers to the tie rods so they didn't hang by their lines. Shouldn't have had to remove any lines.
  5. Jan 30, 2012 at 12:36 PM
    TRDChris
    La Puente
    5 lugger
    I made sure to refill the reservoir when it was getting low on brake fluid. When I was done installing the kit, and drove it for the first time, the brake pedal would sink in and thats why I bled the brakes thinking that their might have been some air in them from when I removed the caliper and re inserted the piston but there wasn't any air? I checked all my tires and your right matt there wasn't any air. It can't be my master cylinder because It's new and I am getting pressure from the brakes. My brakes are working its just that my pedal is sinking to the bottom. I thought maybe I might have damaged the lspv so I bought a new one and no It wasn't that either!
  6. Jan 30, 2012 at 12:38 PM
    TRDChris
    La Puente
    5 lugger
    I just called fabtech and they said it has to be that air got into my brake system or a leak but it's niether
  7. Jan 31, 2012 at 9:50 PM
    TRDChris
    La Puente
    5 lugger
    Anyone have any idea on this problem?
  8. Feb 1, 2012 at 9:50 AM
    MowTaco
    Kansas
    Did you get an rear brake proportioning valve relocation bracket? That's about the only thing I can think of other than air. My rear came with one so I don't know what it would feel like without it but it is definitely sending less braking pressure to the rear, which would cause your pedal to feel softer. I doubt it would cause the pedal to go all the way to the floor but it's possible.
    Try loading the shit out of your bed with whatever you can find for weight. This'll cause the rear to get more brake pressure and see if it feels more normal.
  9. Feb 1, 2012 at 11:46 AM
    TRDChris
    La Puente
    5 lugger
    Yea the shackles came with the relocation bracket and I installed it. I tried removing the bracket and while I held the proportioning valve at several different heights and my dad would be stepping on the brake to see if it might have been the height that was the problem but it wasn't that either. I even tried reinstalling the valve where it had been at before the lift install because joel told me he lifted his rear with leafs that added 1.5 inches and they didn't come with a relocation bracket but my truck was still braking the same. That's what I think is happening as well. The valve is sending less brake pressure to the rear.....
  10. Feb 1, 2012 at 1:55 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    I doubt the bpv bracket helps much if at all I can still lock up all 4 tires even after the bigger tires heavier rims and lift. Only thing else I could think of was a kinked hard line but I'm stumped too
  11. Feb 2, 2012 at 5:35 PM
    Bike2peak
    Bike2peak Member
    Joe
    Colorado
    99 TRD SR5 xcab blacked out
    Work in progress
    New doesn't always mean good. if it's very new, I'd suspect it. a bad master cyl can provide you with some brake pressure, but leak internally past the piston seals. If the system wasn't opened, there shouldnt be air in the lines.
  12. Feb 3, 2012 at 12:24 AM
    TRDChris
    La Puente
    5 lugger
    Me and my dad are thinking it's the braking proportioning valve
  13. Feb 3, 2012 at 9:35 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Didn't you swap that already?
  14. Feb 3, 2012 at 12:34 PM
    TRDChris
    La Puente
    5 lugger
    yea but a used one......we don't know what else it can be?...
  15. Feb 3, 2012 at 1:51 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Shit man I have no clue
  16. Feb 3, 2012 at 2:16 PM
    TRDChris
    La Puente
    5 lugger
    Maybe I should sell it and get a 2nd gen lol
  17. Feb 3, 2012 at 4:22 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Sell it to me so I can LT it :D
  18. Feb 3, 2012 at 8:42 PM
    TRDChris
    La Puente
    5 lugger
    I'm going to get burried with that truck:D
  19. Feb 3, 2012 at 10:50 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Lol poor tailpipe :O
  20. Feb 7, 2012 at 4:51 PM
    AmeriMotor
    AmeriMotor Well-Known Member
    American Motorsports
    Vista
    Offroad Fabrication
    TRDChris you have an air bubble in your brake system, even 1 little bubble can cause some problems. You should start by filling your brake resivor up first then pump your brakes 3 times. Then start at the closet to the master cylinder brake caliper driver side front, then passenger side front, driver side rear then passenger side rear. Bleed as much fluid threw your lines as possible. try to open each valve on the caliper atleast 3 times with pumping inbetween opening and closing. I cant say if this happened but when you install the spindle the caliper was usually turned upside down which has cause an air bubble in your brake system.
