Need help with new button switch lighting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eeoman, Jan 17, 2019.
  1. Jan 17, 2019 at 8:59 AM
    eeoman
    eeoman [OP] Member
    Central Arkansas
    2018 Tacoma TRDOR
  2. Jan 17, 2019 at 7:08 PM
    Andrew S
    Andrew S New Member
  3. Jan 17, 2019 at 10:22 PM
    njburchardt
    njburchardt Well-Known Member
    Nate
    2016 Silver Tacoma
  4. Jan 17, 2019 at 10:50 PM
    porterx
    porterx Well-Known Member
    If it were me, I'd put a resistor inline with the light. Either figure out the resistor value that you need with ohms law or put in resistors until you find the value that makes you happy.
  5. Jan 18, 2019 at 5:51 AM
    Andrew S
    Andrew S New Member
    Keep reading in that thread past the paper filters, another member goes into detail about adjusting brightness via resistors...
  6. Jan 18, 2019 at 5:55 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    This could be don with spring clips or test leads.
    Just lay out your resistor selections on the floor, put the test leads on the IL line, then connect each resistor till you find the "sweet spot". Then pull the test leads and permanently attach the resistor.
    porterx[QUOTED] likes this.
