Need help with rear e-brake cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by Xbeaus, Oct 22, 2015.
  1. Oct 22, 2015 at 12:59 PM
    Xbeaus
    Xbeaus [OP] Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    My 98 SR5 V6 Xtra Cab 5 speed needs the rear e-brake assembly. The cable is siezed up inside the sleeve. I sourced some Toyota part numbers and came up with two of them. 46420-35541 and 46410-35740. I used my frame code and VIN. Went to Napa and referenced the 46420 number but it's to short. errr.... Any help would be appreciated! Do I even have the right part numbers?
  2. Oct 23, 2015 at 11:41 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Had the same issue. I'm a bit shocked at how little information there is to be found online about this considering the only after market cable that seems to be in production, made by Dorman, was too short. I cut a piece off my old cable and fastened the two together but I wouldn't recommend this. My next best solution was to just hit up a junk yard.
  3. Oct 23, 2015 at 11:51 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  4. Oct 23, 2015 at 1:06 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If it was too short, maybe you got a regular cab cable, assuming you are extra-cab.
  5. Oct 23, 2015 at 1:24 PM
    Xbeaus
    Beau
    I have an extended cab. I ordered the 95" one from rock auto. It is dorman. Says it's the cable for the extended cab. Bunch of hoopla!
  6. Oct 23, 2015 at 5:33 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    F*** that shit !
    Here's what I got for a battery when I entered my TRD VIN number. I don't think so... :
  7. Oct 23, 2015 at 5:35 PM
    keakar
    karl
    louisiana
  8. Oct 23, 2015 at 5:51 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I had such poor luck with aftermarket Emergency brake cables as long as I can buy E-brake cables from the dealer I will.
  9. Oct 23, 2015 at 6:06 PM
    tan4x4
    Rick
    Folsom, CA
    This is likely the best solution. It can be a bit confusing
    Aren't there 4 separate cables? One from the cab to the 'bell-crank' underneath, another one from the 'bell crank' back to the rear axle, then 2 that go out to each backing plate?
  10. Oct 23, 2015 at 9:17 PM
    Xbeaus
    Beau
    $127.00 at my dealer. Dorman is $44.00. I'm gonna give it a try. If it doesn't work off to the dealer.
  11. Oct 24, 2015 at 3:06 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Two cables on the extended cab (my 2000) in any case the front cable to the intermediate lever from the handle in the cab
    The rear cable from the intermediate lever to the bell cranks mounted on the brake backing plates .
    If I go look I can most likely get the correct part #
    I understand we all need to save where we can.
  12. Oct 24, 2015 at 8:39 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    It won't be the right size. Look for a used one that you know came off an x-cab.
  13. Oct 24, 2015 at 10:58 AM
    Xbeaus
    Beau
    Well, the measurement of 95" is almost exactly what mine is that I took off. It's odd. The cable is about froze in the sleeve. I can pull it with a vise grip and for lack of a term feels " gooey ". Lol.
    Not taking a parking break for granted again! Sucks when you don't have one. I've been under my pickup so many times I about know every nook and cranny.
  14. Nov 10, 2015 at 6:41 AM
    Xbeaus
    Beau
    Well, rockauto part was wrong. Someone said it would be they were right. $137.00 for oem one. At least it will be the right one. dealer looks up by vin
