Need help with steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprighunter, Mar 10, 2022.
  1. Mar 10, 2022 at 7:49 AM
    Sprighunter
    Sprighunter [OP] Member
    2010 Tacoma sport
    2.5" suspension lift, upper and lower control arms, add a leaf in rear with icon shocks
    New here so be easy on me. I've got a 2010 Tacoma sport long bed. I bought it last year from the original owner, it had the frame replaced two weeks before I bought it, under the factory recall. Bone stock when I bought it. I installed a 2.5" suspension lift in the front, with new upper and lower control arms, ball joints, replaced hub assemblies, have replaced the rack and pinion steering and a few other things. Everything is brand new as far as suspension on the truck.
    That being said!!!! I still have a wobbly steering wheel. I feel like when I'm going over any type of bump or dip in a road I'm constantly getting my steering wheel rocking back and forth like crazy. I've had it into the suspension shop 9 times and they can't find anything.
    Has anyone dealt with this? I love the truck, love the suspension but the steering is driving me nuts. Off road it's miserable to drive and that's what I bought it for. I don't know if it's from when they did the frame replacement or what? HELP!!!
  2. Mar 10, 2022 at 8:29 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Welcome to TacomaWorld! You mentioned all the suspension work but nothing about doing an alignment or wheel/tire balancing. Have you checked those things? What about tie rod ends?
  3. Mar 10, 2022 at 8:32 AM
    Sprighunter
    2010 Tacoma sport
    Thank you for pointing that out! It's been aligned a few different times trying to fix it, they've tried different caster settings and location points, Inner and outter tie rods have all been replaced as recent as 2 weeks ago when I did the steering rack, brand new tires and rims within the last 4 months, just had them balanced and rotated again last week.
  4. Mar 10, 2022 at 8:33 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, can you post your last alignment sheet specs?
  5. Mar 10, 2022 at 8:38 AM
    Sprighunter
    2010 Tacoma sport
    They aren't saved in the computer at the suspension shop that has done all the work for me unfortunately
  6. Mar 10, 2022 at 8:42 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    What about the slop in the rag joint? Common problem, common complaint
    Let me try to find the thread.....
    reallifedog, Toy4me and wi_taco like this.
  7. Mar 10, 2022 at 8:46 AM
    D2.
    Dan
    Nova Scotia, Canada
  8. Mar 10, 2022 at 9:02 AM
    Sprighunter
    2010 Tacoma sport
    Thank you for sending that to me! I'll be the first to admit I am not mechanically inclined. I am planning on taking the truck to the Toyota dealership I've always worked with over the years. I am wondering if it's worth having them replace the steering shaft.
  9. Mar 10, 2022 at 10:15 AM
    D2.
    Dan
    Nova Scotia, Canada
    I'd only replace the steering shaft if that's actually the issue.
    dianosis could be as easy as a friend sitting in the drivers seat turning the wheel left to right while you hold onto the steering shaft to see if you feel any "clunks" or excessive movement.
    usually the steering shaft ( lower portion in the engine bay ) seizes up causing difficult turning. I would investigate the rag joint first.
  10. Mar 10, 2022 at 10:39 AM
    Sprighunter
    2010 Tacoma sport
    Thank you for all the info!!! I'm going to see if there are any Toyota enthusiasts here in Utah that may be able to help and diagnose it with me as well!
  11. Mar 10, 2022 at 12:02 PM
    Sprighunter
    2010 Tacoma sport
  12. Mar 11, 2022 at 8:09 AM
    D2.
    Dan
    Nova Scotia, Canada
    Yup, That's the rag joint, and a cause of a lot of peoples "clunks" or bumps felt in the steering wheel.
    what's interesting is on that intermediate shaft, if you look lower down towards the steering rack, there is the other U-joint ( the one that usually seizes up and causes hard steering, or clunking while turning the wheel ) so really there is a lot of moving parts on that whole series of parts that could be causing your issue.
    I'd do what he did and pop off that cover and do the old wiggle test, see if your satasified with that being the culprit before putting any money down on a fix
  13. Mar 11, 2022 at 8:13 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Another option. The bushings are bad on the steering rack? Or it wasn’t torqued down properly?
    D2. likes this.
  14. Mar 11, 2022 at 8:17 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sounds like bump steer. Really need to see what caster is set at.
  15. Mar 11, 2022 at 8:21 AM
    Sprighunter
    2010 Tacoma sport
    We are planning on doing the wiggle test and replacing that intermediate steering shaft this weekend. When I had the steering rack done, I made the dealership put the tech on it that i've worked with for years, he's the only one i'll let work on my trucks when I take them to the dealership. As far as the caster goes, i'm going to track down the paperwork today to see what it's set at.
    Thank you for all of the help on here!
