need help with suspension problem
Discussion in 'Suspension' started by vwgolf02, May 15, 2009.
  1. May 15, 2009 at 4:39 PM
    vwgolf02
    vwgolf02 [OP] Member
    My truck was involved in an accident to the drivers side. Now my left front wheel isn't straight. Whenever I turn, it the tire scrapes my fender under liner. It isn't in the middle of where it should be. Also the wheel stand slanted inside. What should I buy to fix this problem?
  2. May 15, 2009 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you had it into a shop?
  3. May 15, 2009 at 5:10 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    alignment?
    you should probably take it to a shop and have them put it up on an alignment rack. have them check out your steering rack and tie rod ends while they are at it.
  4. May 16, 2009 at 6:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Like what Chris said....
    Did you have it at a shop?
    Do you have any pictures of the damage immediately after the accident?
    What you describe could be tons of things...we need more info and more pictures.
  5. May 16, 2009 at 7:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 for a shop- They can check alignment, make sure your rims are still in round, and make sure all the bits and pieces are working properly/set correctly
  6. May 16, 2009 at 11:10 AM
    vwgolf02
    Yeah, the rim was bent, so i replaced with different rims. I should just go to a shop for them to see whats wrong.
