Need help with Tires!!
Discussion in 'Wheels & Tires' started by lude50, Apr 17, 2013.
  1. Apr 17, 2013 at 1:31 PM
    lude50
    lude50 [OP] Member
    Pennsylvania
    08 Tacoma TRD
    Running boards
    I have a 2008 Tacoma 4 door Crew Cab. IT has stock tires on it now , but I want to get new tires. I was curious as to how big I could go before I run into problems. i.e. rubbing , cutting. They are 245/65 R17 . . Was looking to go with a more aggressive tire. Let me know what you think. I already have a few tires in mind. Thanks!
  2. Apr 17, 2013 at 1:35 PM
    Large
    Large Red
    absolutely no rubbing at all, 265/65/17.. maybe a little rubbing with stock wheels go with 265/70/17.. aftermarket wheels just stick with 265/65/17
  3. Apr 17, 2013 at 1:40 PM
    fireroad
    fireroad Well-Known Member
    McCall, ID
  4. Apr 17, 2013 at 1:43 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am running 265/75R16 for three season tires and 245/70R17 for winter tires...I recommend the 265/75R16 for the ideal tire size on a stock truck.
    Howard
  5. Apr 17, 2013 at 1:51 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    265/75/16 or 265/70/17 on stock wheels should not rub 95% of the times, still depends on the particular tire. But even in those rare cases, removing front mudflaps, or getting ones that do not have that "bulge" OEM front flaps have will solve that problem.
  6. Apr 17, 2013 at 5:07 PM
    UCKYUK
    UCKYUK Well-Known Member
    Any advice as to what flaps are a good replacement to the OEM front flaps, that don't have that bulge? I just switched rims to a set of pro comps yesterday, and am rubbing on the mud flap bulge, but only on bumpy turns (I did already remove that little flap on the front section of the wheel well).. Was gonna trim that bump out of the front flap, but if anyone knows a nice replacement, I would just as soon remove them and order a new set that won't give me issues. Thanks!
