need help with tranny fuild change
Discussion in '1st Gen. Tacomas (1995-2004)' started by dcasillas, Aug 8, 2009.
  1. Aug 8, 2009 at 11:32 AM
    dcasillas
    dcasillas [OP] Well-Known Member
    san diego
    2004 prerunner quadcab
    donhoe coilovers,total chaos arms
    never played around with tranny need some help 04 tacoma trd
  2. Aug 8, 2009 at 3:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....you can do a simple drain/refill............just remove the drain plug,then fill back up with toyota's t-iv(t4) fluid. or do as i did............
    i drained the oil, then removed the pan and cleaned the magnet and sprayed out the screen/filter with brake cleaner. removed the old gasket material from the pan, used new rtv silicone for a new gasket and bolted back up. then refill. the hardest part was disconnecting the dipstick tube.....it comes apart near the middle. when you put it back.....use a lil lube on the o-ring and it will go back on alot easier. be sure to use toyota t-iv fluid in that tranny tho.
  3. Aug 9, 2009 at 11:25 AM
    dcasillas
    san diego
    how many quarts u use
  4. Aug 9, 2009 at 3:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....on my truck,when i drained it, then dropped the pan.....it was 5 quarts........but they will vary a little bit. yours may be 4 quarts if you do just a drain and refill.
  5. Aug 9, 2009 at 9:15 PM
    dcasillas
    san diego
    yea the dealer said 2 quarts
    but i measured old fuild it was 4.5
  6. Aug 9, 2009 at 9:29 PM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    Is this an auto or a manual? Am I missing some piece of information that indicates which it is? Because it is obviously completely different for each tranny...
    -Sam
