Need help with wiring - 2010 non-JBL stereo
Discussion in 'Audio & Video' started by Nixinus, Dec 13, 2019.
  1. Dec 13, 2019 at 3:43 PM
    Nixinus
    Nixinus [OP] Well-Known Member
    Oregon
    2010 4x4
    Vehicle is a 2010 non-JBL TRD. Stock radio was single disc, non-nav unit (as basic as it gets).
    I am trying to figure out how to run the backup camera video feed on the new HU. I would like to use it anytime but also have it turn on with reverse. My idea is to follow the guide here using a PAC VOLT-39. I will also use the reverse trigger from the mirror to trigger the radio.
    I found a thread here that taps into wires by the fuse box but this way turns the mirror on. Is there an easier way to send the video from the mirror to the new HU?
    I read through many threads and on the newer 2nd gens there is a camera wire going to the head unit. When I took my stock HU out, I found two plugs that have shielded wires in them. Can you help me figure out what these plugs are for? I think 1 is for the steering wheel controls.
  2. Dec 13, 2019 at 4:29 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The white one is steering wheel controls and AUX input
  3. Dec 13, 2019 at 5:54 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    And unless your camera shows on the factory radio, there isn’t camera wiring behind the radio. You’re stuck grabbing the wires over at the fuse box. If you don’t want the mirror to come on, just unplug the connector from the back of it
  4. Dec 13, 2019 at 6:10 PM
    Nixinus
    Oregon
    2010 4x4
    If I unplug the connector at the fuse box then I need to provide 6v power?
