Need Help!!
Discussion in 'Towing' started by DocsTacoma, Dec 11, 2012.
  1. Dec 11, 2012 at 2:20 PM
    DocsTacoma
    DocsTacoma [OP] Well-Known Member
    DFW, Texas
    2012 Tacoma DCSB 4WD //TRD Sport
    BFG Mud-Terrains, TRD Skid Plate, TRD Exhaust, AFE Pro Dry-S Air Filter, Flyzeye Interior LED Light Bar, Bilstein 5100's (Front @ 1.75"), Firestone Ride Rite Air Bag System, Avid Light Bar
    I just installed new 14x5.5" Sendel T05 wheelson my trailer.
    However, I can't fit the wheel center caps on because the wheel bearing cover/cap/protector is too long and won't allow the wheel cap to fit.
    Any help or advice would greatly be appreciated!
    Thanks in advance!
  2. Dec 12, 2012 at 11:00 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Are those grease fittings in the center of those caps? If so, you can probably find some caps without the fittings. They should be shorter.
  3. Dec 12, 2012 at 2:45 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    X 2 on replacing the EZ lube caps with standard caps. You may want to measure first to make sure there is enough room with a standard cap. IF not enough room you are stuck with it the way it is.
    ALso, from the look of the those hubs it appears those bearings have not been checked in a loooong time or even lubed. . Lots of built up crud there. May want to service them before there is a failure while you are hauling.
  4. Dec 13, 2012 at 5:53 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Yes, they look nasty on the outside but they may be ok on the inside. I would pull those caps off the end of the hubs and possibly pull the whole hub apart and re-grease the bearings and then instal a regular cap. Then you might have room.
  5. Dec 14, 2012 at 8:49 AM
    DocsTacoma
    DFW, Texas
    Thanks for the advice guys!
    Essentially, what I needed was a shorter/smaller dust cap. And after looking around, I found the size I needed (2.33").
    Here are before and after pictures.
    Thanks again guys!
  6. Dec 15, 2012 at 7:01 AM
    RyanLikesTacos
    RyanLikesTacos Well-Known Member
    Charlotte, NC
    Looks very tidy now!
