Need idea for mounting box in bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Sep 20, 2010.
  1. Sep 20, 2010 at 5:19 AM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    So I bought this big rubber maid type trunk to store luggage or what ever else in for my up coming vacation, and I am trying to think of a way to secure it to my truck. Obviously the easiest way is to drill into the bed, but I really want to mount it into the bed rails but I need some ideas on how to do it
  2. Sep 20, 2010 at 5:56 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
  3. Sep 20, 2010 at 6:10 AM
    evile
    Orlando, Fl
    I like your idea probably the easiest thing to do
  4. Sep 20, 2010 at 7:14 AM
    pcledrew
    pcledrew Well-Known Member
    BC
    '17 TRD Sport DCLB
    Shove a bolt through it while it's tight against back wall. Pass bolt through the center drain hole in the truck bed. Hope this makes sense.
  5. Sep 20, 2010 at 12:46 PM
    evile
    Orlando, Fl
    so here is what I did. Went to home Depot got 4 bed tie down with a d ring in the middle used self tappers put 2 on the front of the bed and 2 on the box and used some chain and pad locks to secure it. I need to tidy up the chains a but pics tonight when I get home
  6. Sep 20, 2010 at 5:15 PM
    evile
    Orlando, Fl
    Bah had to work late now its dark but I did get some master locks on it so its as secure as I can make it obviously if some one really wants it they are gonna get it know mater what I do but I think I am set now. Pics as soon as I can I promise
  7. Sep 20, 2010 at 6:53 PM
    pizzo
    pizzo Well-Known Member
    canada
    09 dc taco trd sport
    damn dude. your bed is so clean!!!!
  8. Sep 20, 2010 at 7:05 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Here is how I did mine.
    The box I used is manufactured by Contico, it's called the Tuff Bin. I added two D-rings to each side of the box to attach the box to the truck.
    I have extra D-rings installed under the bed-bolts in the front and middle of the bed, a padlock was passed through the D-ring in the corners of the box and the front of the bed, this is all that was needed to hold the box to the bed.
    With the box loaded and sitting on the bed mat it does not move. When I went trailing I attached two tie-downs to the other D-ring mounted on the box and attached these to the extra D-rings mounted under the bed-bolts in the middle of the bed.
    I have no use for a box in my truck all of the time. When I go trailing or camping this works perfect. It holds my tools, floor jack and a small compressor. On vacation I also had all my carwash stuff in there along with all the tie-downs and bed-net I used to secure my load. Takes about two minutes to put the box in or take it out.
  9. Sep 21, 2010 at 5:13 AM
    evile
    Orlando, Fl
    I couldnt find Drings like that at Home Depot so I had to go with a different set up but I should be able to get some pictures up tonight. Its locked down good though with chain and 3 magnum masterlocks hehe
  10. Sep 21, 2010 at 8:50 AM
    akdisney
    akdisney Well-Known Member
    Alan
    CA
    PreRunner SR5 V6
    Thule 422xt rack w/ XK1 rack adapter, uvw tool chest box, nerfBars
    I use (L angle bracket) to bolt the box to the back rail.
    use T nut that was made to fit.
    Who can say that you can bolt to the rail, Use T-bolt or Car bolt.
  11. Sep 21, 2010 at 10:30 AM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Looks great!
  12. Sep 21, 2010 at 10:43 AM
    Larry
    Larry CARL
    CARL
    vvvv FTW vvvv
  13. Sep 21, 2010 at 11:28 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Easiest thing to do is to drill a hole in the bottom of your rubber maid and fish a carriage bolt through the existing drainage holes and twist a wingnut on it from under the truck. Put a nice big washer in the rubbermaid to distribute the pressure......wham bam.
  14. Sep 21, 2010 at 1:10 PM
    Xshark
    Xshark Well-Known Member
    How about an old ammo box? I know this has been done before. I've seen the thread, but all the pics were obsolete.
    I am going to take 2 50cal ammo boxes, drill some holes in the side of them, and mount them on the rail. (going to use some t-nuts to attach to the rail.
    I plan to carry most of my tie-downs & jumper cables in them.
  15. Sep 21, 2010 at 3:20 PM
    evile
    Orlando, Fl
    YAY pictures. one of the things I wanted with this box was the ability to remove if easily if I had to only have a 5 foot bed some times I need all the bed space I can get. This box is primarily going to be used to keep my luggage in when I go on vacation.
    Sorry about the sunlight it was bright outside hehe
    tacobox_2_2ee537cfc0259aad475cf8e1d6d23b1abf36563a.jpgtacobox_3_a6b4012c94a2480cc042cccf7bc1821c3626451b.jpg
  16. Sep 22, 2010 at 8:45 AM
    akdisney
    Alan
    CA
    PreRunner SR5 V6
    I thank you:wave:
    I now need to repaint (L angle bracket), The sray can say it is black but came out dark gray.
    I will take apart by unbolt from rail use Hex wench and wing nut in side the chest tool box
