Need info for removing front coil pack to replace bushing!
Discussion in 'Technical Chat' started by JustADummyInATaco, May 8, 2017.
  1. May 8, 2017 at 3:09 PM
    JustADummyInATaco
    JustADummyInATaco [OP] Active Member
    Riley
    UTAH
    06 sr5 driven by noob
    6" Procomp Coilover lift, 18 inch motometal wheels, too small of tires, magnaflow exaust, highly illegal tint, poser TRD off-road stickers, TRD intake, NFAB nerf bars, lots of love.
    So I need to replace the bottom strut bushing on the front drivers side strut on my 06', I have a 6 inch procomp lift. Can I get the coil pack out without having to remove the UCA and the steering spindle? And when it comes time to put the new bushing into the strut, do I need a press to do it or can I do it with a bench vise or what ever redneck method?
  2. May 10, 2017 at 3:35 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    You didn't say what struts you have, but I'll assume they are stock with the 6" spacer. If you have to replace the bushing I would really consider replacing the shock since you probably don't realize how much better a ride you can with a little more control. If you want to keep the ones you have the bushing can be pressed out but I can tell you unless you have a freakin helluva vice with a long breaker bar on the screw you won't develop enough pressure to remove it. I've had fair luck with burning them out but it's not fun. Check on youtube for a dozen examples.
    Check out the stickies on shock removal.
    https://www.tacomaworld.com/threads/how-to-front-shock-spring-removal.31862/
    https://www.tacomaworld.com/threads/icon-stage-4-install-detailed-instructions.196192/
