Need info on lifting
Discussion in 'Suspension' started by DanGer, Feb 15, 2009.
  1. Feb 15, 2009 at 7:15 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Hey guys, I am almost 100% positive this has been posted AT LEAST once before but I can't find anything about it now. I know absolutely nothing about lifting. I want to put larger tires on when its time to change them but I want to know what sizes fit on stock height and 3" lifted height. Thanks all
  2. Feb 15, 2009 at 7:17 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    285/75/16 or 285/70/17 for the 3" and 265/75's for stock
  3. Feb 15, 2009 at 7:22 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    The 285 will need some trimming of plastic to avoid some minor rubbing.
  4. Feb 15, 2009 at 7:22 PM
    Dockhead
    Dockhead Formarly 08TRD4X4RadientRed
    Chico, CA
    08 ACC 4X4 TRD OR
    TRD Seat covers, K&N Series 77 intake, TRD plate frames, iPod interface
    Depending on the 3 inch lift kit you get you should be able to fit 32 or 33 inch tires, without trimming. Stock I've heard a 275 without trimming.
  5. Feb 15, 2009 at 7:37 PM
    DanGer
    so with the TSB done would i need to lift if i wanna put on 275s. they replaced all the shock absorbers and added the leaf in the rear. I never measured the front but the back went up a bit. Will it settle back down once the shocks are broken in?
  6. Feb 15, 2009 at 7:58 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    265/70/17 and no lift
    275/70/17 stock height
    I hear you may have to take the mud flaps off though.
    The ride should settle down a little.
  7. Feb 15, 2009 at 8:04 PM
    DanGer
    thank you very much for the info! I'll have to dig in an get educated about all this. The only reason I'd want to lift is for offroading/mudding tires. If i'm wrong in trying to lift for this please inform me!
