Need more gas mileage
Discussion in 'Performance and Tuning' started by Etohanee, Aug 14, 2008.
  1. Aug 14, 2008 at 1:37 PM
    Etohanee
    Etohanee [OP] New Member
    I would like to get a cold air intake, but need to know which one and a programmer. what else can i add to increase the gas mileage and how will it affect my car.
    - eta
  2. Aug 14, 2008 at 1:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    either go with the whole urd setup....intake, maf calibrator and exhaust, or just skip on the intake altogether(not woth the $$$,in my opinion), and just get a good high flow filter such as the afe pro dry s drop in filter. some people are gettign as much as 3 mpg with just that filter alone. and be sure to remove your secondary air filter for a bit more gain......and its located in the airbox.
  3. Aug 14, 2008 at 2:09 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Where would I be able to buy a AFE pro dry s drop in filter? Online vendors are where I am primarily looking to buy one.
  4. Aug 14, 2008 at 2:18 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Ok here is a list of thing you can do to increase milage.
    1. Cover the bed
    2. Cover the wheels with A solid cover. you may need to make a raised lip to let Air in for brakes.
    3. Cover the gap with brushed between the fenders and wheel.
    4. Lower the truck as well
    5. Add a front Air splitter
    6. Add side skirts to remove mot of the gap bwtwen the road and your truck.
    7. whole urd setup
    8. lighten the truck as much as you can
    9. Runn the lightest wheel you can and thinnest tires that are safe
    10. Was and wax the truck oten to keep it Smooth.
    11. Acid dip the frame and body panel to lighten them up. Old old trick...
    12. use a thinner paint job old trick.
    THese are extreams but this is what it might take
  5. Aug 14, 2008 at 2:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check with some of the guys here, as there was a group buy recently for the afe filter, and you may be able to get in on the deal still.
  6. Aug 15, 2008 at 1:54 AM
    S-Runner '01
    S-Runner '01 Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    One way I've found to increase my gas mileage is to slow down. I have an '01 S-Runner and a couple of weeks ago I drove from here in Yakima WA to Puyallup Wa and back, a distance of about 160 miles each way. On the way over I took the freeway (I-82 from Yakima to Ellensburg and I-90 from E'burg to Seattle and I-5 down to Tacoma/Puyallup) and drove approximately 75 miles per hour. When I got there I filled up and figured my mileage at 22.5 mpg.
    I left Puyallup and came back via highway 410. This highway is mostly 2 lane and the maximum speed limit is 55 mph. About 60 miles was through Mount Ranier National Park where the speed limit is 45 mph. When I got back to Yakima I filled the tank again and this time I got 28.6 mpg. An increase of 6.1 mpg. The only difference was my speed. I wouldn't have believed that slowing down could make so much of a difference but it did.
    I bought my truck a month ago down in Murrieta CA and drove it back to Yakima, a distance of a little over 1100 miles. On the way back I drove about 70 mph most of the way and since it was over 100 degrees down in Southern Cal, I used my air conditioner almost all the way and I got 20 mpg.
    If you really want to get the best mileage, turn off your A/C and slow down. It may take you a little longer to get where you are going but if saving gas money is important to you it is well worth it.
    Jerry
    PS This past week I filled up my tank with Shell premium and took a 200 mile trip from here in Yakima down to the Tri-Cities and back. I took the back roads all the way and held my speed down to 35-55 mph all the way and when I got back to Yakima I filled up and my mileage went up to 29.3 mpg.
    I'm sold on slowing down and saving my gas money.
    jj
  7. Aug 15, 2008 at 1:56 AM
    S-Runner '01
    Jerry
    BSP '01 S-Runner
    An Addendum:
    Yesterday, I did the deckplate mod. We'll see if that helps or hurts my mileage.
    jj
  8. Aug 15, 2008 at 1:03 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Cheapest ways to increase gas mileage is to slow down (80mph = 13.5mpg, 60mph = 18mpg on my truck) and make sure your tires are properly inflated.
  9. Aug 15, 2008 at 2:58 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i saw a taco with no bed. it was like a flat bed truck. looked pretty good imo.
  10. Aug 15, 2008 at 4:16 PM
    GasTiresOil
    GasTiresOil Glockin
    11 Tundra RW
    To get better gas mileage I started off by slowing down a bit. I had heard for years that CAI many times actually hurts gas mileage so I went with the TRD intake. (designed by Toyota, keeps the proper air/fuel ratio). And I had also heard that synthetic oil can give 2-3 miles more per gallon which I never believed.
    I got consistent 17-18 mpg on my 08, then switched to synthetic, drove it kinda easy, and got high 22mpg on my first fill up after changing the oil. I still dont really believe it, but I got almost 380 miles to the tank where I would usually get around 300. Give synthetic a try, its all I'll use now.
  11. Aug 16, 2008 at 4:15 PM
    Hwy61
    Hwy61 Active Member
    08 DC TRD Sport
    i thought said filter was a secondary filter?
  12. Aug 16, 2008 at 4:37 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    I pulled a flowmaster muffler/tailpipe OFF of my 95, 3.4 liter V6 & LOST 3mpg.
    So by adding one will you gain 3mpg???
  13. Aug 16, 2008 at 4:49 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    On your 08,You may see a diff of 2mpg. :)
  14. Aug 16, 2008 at 9:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah....sec. filter is a charcoal filter located past the air filter isn the air box. you remove it and gain a bit of performance(butt dyno anyway), then you can a good filter like the afe!!:)
