Need new timing belt at 165k miles
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruben526, Dec 4, 2017.
  1. Dec 4, 2017 at 3:41 PM
    Ruben526
    Ruben526 [OP] Well-Known Member
    Ruben
    Salem, Oregon
    2001 Tacoma SR5 Prerunner
    Solo MOTORSPORTS LT basic kit with king 2.5 8” coilovers Advanced fiberglass fenders all around Deaver J59 springs with rear shock relocation to outside frame 14” 2.5 sway away triple bypass sway away 2” 2.5 bump stops 35” general grabber X3 17” addicts Total chaos spindle gussets
    anyone have recommendations of where to go in bakersfeild or South Bay CA area? I wanted to do it my self since Iv done everything myself so far but ppl have convinced me to just get it done so I don’t ruin my motor 3.4L thanks in advance also if you don’t mind roughly how much it cost with a water pump thanks!
  2. Dec 4, 2017 at 7:59 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    You can do it yourself and not ruin your motor. Here's a couple videos you can use. In the first video we struggled to get the timing belt on and I ended up using a trick with a plastic bicycle tire lever to get the belt onto the last pulley. In Part 2, we show a much easier way to get the belt on so use that technique instead.
    https://www.youtube.com/embed/vHC46ypHxWc
    https://www.youtube.com/embed/mErd7xoBS9I
  3. Dec 4, 2017 at 9:17 PM
    Ruben526
    Ruben
    Salem, Oregon
    Thank you! I’m watching rn
    Dalandser likes this.
  4. Dec 4, 2017 at 9:24 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    This is one of the easier engines out there. Plenty of room, rear wheel drive. You can dooo itttt.
    Ruben526[OP] and Dalandser like this.
  5. Dec 4, 2017 at 11:11 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Dec 5, 2017 at 1:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What kind of people are telling you to pay big $$$$ to have this done??
  7. Dec 5, 2017 at 3:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sounds like the people you've been listening to are unskilled naysayers.
    It does require a bit of patience and attention to detail.
    Plan to have all parts on hand, a sheltered area to do it in in case of weather issues, have all the tools on hand, have alternative transportation available if it takes longer than you thought. Allow yourself 2x the time the readings/video you watch calls for. You may not need it, but you also don't want to be in a rush.
    You can do it. If you're interested in saving a few hundred clams. And with that attention, you'll have a more through job than a shop just interested in getting in and out.
  8. Dec 5, 2017 at 6:06 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I did mine myself when my water pump ground itself into a lockup condition. The factory belt lasted 133k miles.
    As for cost, I purchased every thing from Rock Auto at one time for about $365 shipped. Water pump, timing belt, tension pulley, idle pulley, accessory belts, cam seals, valve cover gaskets, and radiator hoses.
    All parts were quality brands and the water pump was the same one used from the factory.
    I had to make a simple jig to hold the crank pulley so I could remove and retorque the pulley bolt. It also worked to hold the cam sprockets when I removed those bolts.
    Figured I was already water pump deep, I may as well change the cam seals while I'm in there.
  9. Dec 5, 2017 at 7:45 AM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    Do it yourself.
    Even easier if it's a manual tranny!
    cruxofthebisquit and Dalandser like this.
  10. Dec 5, 2017 at 10:14 AM
    Ruben526
    Ruben
    Salem, Oregon
    Car guys lol
  11. Dec 5, 2017 at 10:16 AM
    Ruben526
    Ruben
    Salem, Oregon
    Yeah I like that idea cause this would be the only thing in my truck I didn’t do myself so far and I don’t like putting faith in a shop that they didn’t make any short cuts. Well I’ll look into getting it done at the parents house as mine is prolly going to snow soon bad timing on my part haha
  12. Dec 5, 2017 at 10:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Where are you getting snow in Torrance? lol
    It's really not that bad and it's worth the time if you have the tools.
  13. Dec 5, 2017 at 10:19 AM
    Ruben526
    Ruben
    Salem, Oregon
    That’s where my parents live lol I don’t live there anymore I live in Tehachapi now haha
    Dalandser[QUOTED] likes this.
