Need Opinions on Lifts/Tires
Discussion in '3rd Gen. Tacomas (2016+)' started by Bergs17Taco, Sep 1, 2020.
  1. Sep 1, 2020 at 5:33 PM
    Bergs17Taco
    Bergs17Taco [OP] New Member
    Looking to get a Lift and tires for my truck but I'm having trouble picking one out. It will be a daily driver but also using it for smaller off-roading. I was looking for a 3.5"-4.5" lift with either 31s or 33s. Just figured would rather get others opinions before buying them.
  2. Sep 1, 2020 at 5:35 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Are you 4wd?
  3. Sep 1, 2020 at 5:39 PM
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, OME887 coils with 5100s for the front, 5160s rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system.
    4.5 inch lift with 31s????o_O That would look really goofy OP. Minimum tire size I would look at on a 4 inch lift is 33s and go up from there.
    I’m on a 2 1/2 inch all the way around lift with 32s and it could use 33s (whether skinny or fat). So 31s on a 4 inch lift. No go...my humble opinion anyway.
    Shellshock likes this.
  4. Sep 1, 2020 at 6:34 PM
    Bergs17Taco
    Yes 4wd
  5. Sep 1, 2020 at 6:40 PM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Gotcha. So with anything like a 4" lift you will need to do a drop bracket kit. Meaning that your front cross member (part of the frame) will need to be cut to allow the front differential to be lowered and keep the CV axle geometry good. Then the kit will have a bracket to weld back to your frame.
    From your needs blocks are probably fine. As long as you don't plan to do high speed off roading or significant flexing on difficult trails.
    https://www.morris4x4center.com/rou...NhJNzeqq8L41nlmYpu5NbmCvc28fC2khoC45oQAvD_BwE
    You will likely rub with 33's. You probably need to do a cab mount chop. Lots of information with quick internet search. With 31s or 32s you'll won't rub and won't need to anything in the wheel well.
