Need Quick Advice- Bilstein 5100 + block?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TBTACO, Jan 15, 2018.
  1. Jan 15, 2018 at 6:19 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    2013 Tacoma Prerunner
    I just dropped off my truck at 4 Wheel. I need some quick advice, as I may have to call back and change things up.
    Just replaced my 1st gen with 2nd gen 2013 Prerunner SR5. I want to achieve a small lift with a nice, level stance. I ordered 5100's all around. I am going to have them at 2.5" in the front (I know it will be a stiffer ride). I also ordered at 1" block for the rear. I ordered these at the advice of a suspension specialty shop (which was too expensive to have service my truck) when I stated I wanted to achieve as high as lift with as level as I could with the 5,100s.
    When I dropped it off at 4 Wheel, the guy said it would be level at 2.5" in front with no mod to the back. I find that hard to believe. I understand that there may be the slightest rake when adding a 1" block in the back, but it seems like if I don't add the block, the front will be higher.
    My question: Which would be closest to being level? With or without a rear 1" block if set to 2.5" in front? I'd rather have a slight rear rake than the front being higher.
    I would prefer not to only raise 1.75, so your answer to the above question is appreciated.
    Thanks!
  2. Jan 15, 2018 at 6:22 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Closest you could get to some rake would be a 1.5" AAl. If the rear bilsteins are extended length you can get the 2" AAL for slight rake.
  3. Jan 15, 2018 at 6:25 PM
    TBTACO
    TBTACO [OP] Member
    Trey
  4. Jan 15, 2018 at 7:11 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Those are stock length bilsteins. I can give you stats from my truck. this was with 5100's, OME 884 coils, and a 2" Add a leaf in the tsb (four leaves total) leaf pack. I had stock length bilsteins in the rear and blew one up by overextending from such a high rear lift. i installed old man emu nitrochargers to remedy that and extended the rear brake lines as well. Now everything is good!
    STOCK TACOMA
    Driver Side Front - 34.25"
    Pass. Side Front - 34.5"
    Driver Side Rear - 36"
    Pass. Side Rear - 36.5"
    MY TACOMA – Bilstein 5100’s, OME 884’s, 2” AAL
    Driver Side Front -36.5”
    Pass. Side Front - 36"
    Driver Side Rear- 38.25
    Pass. Side Rear- 38.25"
    1.5” AAL means about 1.25” of rear rake = 37.5” in rear total.
    MAY SETTLE TO AROUND 1.25” AAL
    2” AAL means about 1.75” of rear rake = 38” in rear total.
    MAY SETTLE TO AROUND 1.5”-1.75” AAL
  5. Jan 15, 2018 at 7:13 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    So by these measurements using a 1" AAL for example, you will have 0 to 0.25 inches of rake. So basically a level truck, I would try to see if they will install a 1.5" AAL in the rear leaf pack.
  6. Jan 15, 2018 at 7:15 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    Would a 1" AAL have the same visual (not performance) effect as a 1" block?
    MurderedTacoV2 likes this.
  7. Jan 15, 2018 at 7:18 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    no problem, man!
  8. Jan 15, 2018 at 7:20 PM
    Pigpen
    Dan
    Northwest Montana
    Tire size will fuck up those measurements. Always measure from center of hub to fender.
    Extended shocks are not needed with an AAL. you're still running off the stock springs, so you're not increasing the down travel of the rear suspension.
    OP, with 5100s set at 2.5" and a 1" block you'll be okay. Factory rake is 2". With a prerunner, you'll get more lift than a 4x4. You may get 3", in which case you'll be glad you did the block.
    Your truck is going to ride like shit though. Enjoy.
    DavesTaco68 likes this.
  9. Jan 15, 2018 at 7:23 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Pigpen - Do you think going 1.75 and no rear mod is the way to go if it is going to "ride like shit"? Because it is a prerunner, I could likely get a little more than what I expected from the middle settting?
    I just purchased 33" ATs, so I want to make sure I don't have any issues.
  10. Jan 15, 2018 at 7:30 PM
    Pigpen
    Dan
    Northwest Montana
    It will help with the steering issues you'll experience going 2.5, and soften the ride. My 4x4 Access Cab got 2.5" of lift set at 1.75. The ride was firm, but felt good. With 255 width tires on stock wheels the steering was fine. With 265 width tires on offset wheels, it steered like an office chair.
    If see where 1.75 gets you and adjust the rear accordingly. Be aware you'll eventually want UCAs to adjust caster to fix your steering issues.
    This could all be avoided by lifting with spindles instead of adjustable shocks. @ChadsPride has a rad prerunner with a 4" spindle lift.
  11. Jan 15, 2018 at 7:32 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Pigpen Thanks for the advice. I have already purchased 17's with 33's to be mounted, so I'm not sure how a 1.75 will accommodate. I'll check out @ChadsPride.
  12. Jan 15, 2018 at 7:34 PM
    Pigpen
    Dan
    Northwest Montana
    Expect to do a CMC.
    Do you already have the 5100s?
  13. Jan 15, 2018 at 7:41 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    CMC if I go 1.75? And yes, I already have them.
  14. Jan 15, 2018 at 7:43 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    My 13 access cab 4x4 I had 5100 set at 1.75 and sat level, it was so level that I added a 1 inch block to get at least a little rake back, looked nose high to often without it, at 2.5 You will want a 1.5-2"aal, my tires were 265/70/17 in this pic
  15. Jan 15, 2018 at 7:48 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I have your exact same set up. 1.5" in the back would be perfect, I have an inch block there and it's not quite tall enough for me. A small amt of rake would be perfect and 1" isn't quite enough.
  16. Jan 15, 2018 at 7:53 PM
    Pigpen
    Dan
    Northwest Montana
    CMC with 33s if they're wide, regardless of lift.
  17. Jan 15, 2018 at 7:57 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Pigpen I'm hoping not. I have been to three professional shops that knew my tire size and setup and they all said I would have no trouble with clearance if I'm not doing any aggressive offroading.
  18. Jan 15, 2018 at 8:00 PM
    Pigpen
    Dan
    Northwest Montana
    I hope it works out fine for you. A little rubbing isn't that big of a deal.
  19. Jan 15, 2018 at 8:01 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Minny Taco, thanks for the response. How drastically did the ride change with the 2.5" up front and the block in back?
  20. Jan 15, 2018 at 8:02 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Pigpen, thank you. I appreciate the insight. Newbie with mods.
