Need Quick Advice- Bilstein 5100 + block?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TBTACO, Jan 15, 2018.
  1. Jan 15, 2018 at 8:03 PM
    Pigpen
    Dan
    Northwest Montana
    I'm guessing the new tires are 285/70/17?
  2. Jan 15, 2018 at 8:03 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    2013 Tacoma Prerunner
  3. Jan 15, 2018 at 8:08 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Mine was kinda the same case except i had 265/70/16's. Now im at 265/75/16's, guess i shoulda asked OP what size tires he had as pigpen suggested here. now pigpen how do you think a 2" ride height increase would make no difference to a shocks extension? Not trying to pick on you here, but i had read up about how a 2" AAL could damage a stock length shock. I said nah that wont happen to me! Few months later i blew a rear shock with 20k on it, its was a trd bilstein one from the factory too. Thats literally all that makes sense to me here, you are increasing the height of the frame which in turn extends the shock past OEM position and when a sudden drop came along it fucked it all up. Am i incorrect?
    Dhannah likes this.
  4. Jan 15, 2018 at 8:16 PM
    Pigpen
    Dan
    Northwest Montana
    It wasn't the ride height that blew out the shocks. It was the added stiffness of the suspension. Those shocks are valved super soft and can't handle what you did to them. I did the same to mine with Ride Rite air bags on stock springs. I blew the rear shocks within 10K miles of installing the bags.
  5. Jan 15, 2018 at 8:41 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Just a heads up, some have to do it and some don't, your alignment depends a lot on it, and most offroad shops don't always know much, I've had my laughs talking to guys at 4wheelparts in my day, either way the CMC is way easier than a lot of people make it seem, I was a little terrified the first time I started cutting on my truck, but you wouldn't know unless I showed you where
    the leafs will still be the factory extended length, the add a leaf only stiffens the arch, standard 5100s in the rear are longer than the leafs extended.
    Pigpen and Dhannah like this.
  6. Jan 16, 2018 at 7:08 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I couldn't tell a difference. It certainly didn't ride worse. HOWEVER I did get the vibration that many ppl get when they lift their rigs. Felt like rumble strips up to about 50 mph and would go away in 4HI. I found there was a TSB for that so I took it to Toyota and they replaced that front bushing with no questions asked and at no charge. I thought they would tell me to eff off since I lifted it, but it wasn't an issue.
  7. Jan 16, 2018 at 8:26 PM
    TBTACO
    TBTACO [OP] Member
    Trey
    @Minny Taco, I just drove it home, no rear block. Actually not as nose high as I thought it would be but just a tad under level. I'd imagine the block would have made it pretty much back to factory rake. I thought I felt a little "womp womp womp" push pull sensation for a minute, but then it seemed to disappear... not sure if I made it up in my head, but I'll be driving her tomorrow to see what's up. Thanks for the insight on the bushing. I'll have to check out all of the TSB for this ride, as I just got it and haven't done my homework.
    I appreciate your response!
  8. Jan 16, 2018 at 8:46 PM
    Pigpen
    Dan
    Northwest Montana
    @TBTACO has a prerunner. There's no front diff, therefore no bearing or need for the bushing.
    What's your center of hub to fender measurement after the lift?
    Oh and :worthless:
