Need Quick Answer, Does Front Diff Drain Plug Have a Crush Washer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boyk1182, Nov 4, 2017.
  1. Nov 4, 2017 at 9:08 AM
    Boyk1182
    Boyk1182 [OP] Well-Known Member
    Timnath, CO
    2014 Toyota Tacoma 4x4
    Need to see if I have to try to find it in the drain bucket..
  2. Nov 4, 2017 at 9:09 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  3. Nov 4, 2017 at 9:09 AM
    Boyk1182
    Timnath, CO
    Thanks, it should be around, this is gonna be fun..
    Unchained 5150 likes this.
  4. Nov 4, 2017 at 9:16 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    R0dzilla75 and Boyk1182 [OP] like this.
  5. Nov 4, 2017 at 9:20 AM
    Boyk1182
    Timnath, CO
    I know, I should have.
    One more question, does the smooth side of the crush washer go towards the bolt head, or the diff? I never noticed them to be different on Dana axles.
  6. Nov 4, 2017 at 9:22 AM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Thats how I install them. Smooth side to bolt head.
    DaveInDenver likes this.
  7. Nov 4, 2017 at 9:24 AM
    Boyk1182
    Timnath, CO
    Alrighty thanks, if it works for you it should work for me.
  8. Nov 4, 2017 at 9:36 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
  9. Nov 4, 2017 at 9:55 AM
    Boyk1182
    Timnath, CO
    Thanks everyone, huge copper ring in the drain bucket. Now I have way too many buckets but back on track.
  10. Nov 4, 2017 at 2:13 PM
    Boyk1182
    Timnath, CO
    Dumb question..
    I have a 2014 SR5 4x4. I used Lucas 80w90 non-synthetic. Am I good? My paperwork says I have a LSD, so I don’t know.
    I am coming from a Rubicon with lockers, so this Tacoma stuff is new to me.
  11. Nov 4, 2017 at 2:16 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Northeast KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Recommend the gasket set linked from Amazon here. I used them and worked out fine.
    Far as oil, I used SuperTech 75-90 from Walmart. I didn't go high end because I'll refill every 30k miles since dirty water is prevalent where I go wheeling. I'm not a Cali Instagram Overlander lol
  12. Nov 4, 2017 at 2:19 PM
    Boyk1182
    Timnath, CO
    No I mean as far as additives, I don’t need any right?
  13. Nov 4, 2017 at 2:23 PM
    dirty deeds
    Nick
    Northeast KY
    I didn't use any. But I'm a manual, if that matters. I think autos are supposed to use the additive.
    There's a thread here with instructions. Should be able to find it in the intro message from Bob when you joined. Some good DIY links in there.
  14. Nov 4, 2017 at 2:23 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I'm not 100% sure, but my understanding is that the limited slip you have is electronic. The TRAC/A-TRAC detects wheel slip and applies the brakes. So you would not need additive. Earlier trucks had mechanical LSDs and those would need additive. I thought the split was around 2009.
  15. Nov 4, 2017 at 2:26 PM
    Boyk1182
    Timnath, CO
    Yea I did use the DIY thread, and it said after 2009, no additive needed. My rear diff also has no sticker saying LSD. I think it is the brake one.
    dirty deeds likes this.
  16. Nov 4, 2017 at 2:29 PM
    dirty deeds
    Nick
    Northeast KY
    We all have LSD best to my knowledge. If it said post 2009 doesn't need it, don't add it. Won't hurt if you do use it though.
  17. Nov 4, 2017 at 2:32 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I believe the only downside to using LSD oil when you don't need it is that it wears out faster. I don't think it would actually hurt anything in an axle like this, though.
  18. Nov 4, 2017 at 2:43 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    You 100% do not need an LSD additive.
    dirty deeds and Boyk1182 [OP] like this.
  19. Jan 20, 2018 at 6:57 PM
    yote
    yote Washington State University
    Mark
    Shoreline, WA
    2002 Ext Cab TRD Off-Road
    Reviving because I was profile creeping.....
    I thought LS additive was for Sport models only?
    Even if you didn't need an LS additive, would it be okay to run it anyway because Mobil 1 is cheap and reliable....
    Asking for a friend :anonymous:
  20. Jan 20, 2018 at 7:05 PM
    Boyk1182
    Timnath, CO
    I think additive is fine to use even if you don’t need it. But if you do need it, don’t not use it. Hope that’s not too many double negatives lol
