Need recommendation of heavy duty 2" ratcheting straps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Failure2Comply, Mar 16, 2013.
  1. Mar 16, 2013 at 1:30 PM
    Failure2Comply
    Failure2Comply [OP] Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    I need to replace my less than stellar Goodyear 1.5" ratcheting straps. I want something rated at 10,000 lbs with "J Hooks" that will last and I can trust to tie my Kubota tractor down with. 10,000 lbs will be overkill which I like but longevity and performance are top needs. What do you guys use and recommend? I also am looking in the $20.00 - $30.00 each strap range as I need two.
    Thanks,
    Edit:
    I was looking at these two so far.
    http://www.northerntool.com/shop/tools/product_200344936_200344936
    http://www.amazon.com/Erickson-7862...2&keywords=heavy+duty+ratchet+strap+10,000+lb
  2. Mar 16, 2013 at 1:33 PM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    Wal-Mart or Nothern Tool has a great selection
  3. Mar 16, 2013 at 1:43 PM
    dirtfondler
    dirtfondler Well-Known Member
    San Jose, CA
    00 F250 7.3L Diesel
  4. Mar 16, 2013 at 2:43 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    truck stops sell them
  5. Mar 16, 2013 at 3:47 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
  6. Mar 16, 2013 at 4:01 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Pm'd with scott, Thank you for serving scott
    If I had a nice Kubota tractor I would pop for some nice straps, at least you can use them on anything in the future. Overkill is a good thing.
  7. Mar 16, 2013 at 4:32 PM
    Failure2Comply
    Virginia, USA
    Considering the little amount you guys are paid for defending our Country, I just consider my tax money part of them as money you deserve. It is a damn shame when a trash collector can make more than the brave men and women of our Military and Law Enforcement. Thank you for your service to our Country!
  8. Mar 16, 2013 at 4:35 PM
    OldGeezer42
    Adam
    Louisiana
    07 DCLB Silver Base
    Just don't leave them behind your truck in Virginia Beach>
  9. Mar 17, 2013 at 4:20 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Lighten up Francis..
    FYI if those straps have any wear, cut, fraying they are junk. They get tossed in the junkpile. I have two the same way. Not useful to tie down cargo.
  10. Mar 17, 2013 at 4:21 AM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
    Yea those are 5K when new. Mine are considerably less now :cool:
  11. Mar 17, 2013 at 7:10 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Appologize for the rant.
  12. Mar 17, 2013 at 7:18 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
  13. Mar 17, 2013 at 8:34 AM
    lj973gm
    Ohio
    06 DCSB 4wd
    You now state it was a joke. You led it to be a joke not me.
    If you were reading about stolen items from US property by anyone would you condone the actions?
    I have pride and care for this country, when I read text stating they were stolen it not correct.
    Not in my 20's but you can jump the that conclusion and the others you wrote.
    No issue with you, just going by what was written. Thank you for clearing it up and serving.
    I feel it is sad where our military has turned and the whole nation. The respect to wear the uniform is not what it used to be. I will leave it at that and not go into deep discussion about the youth of our country.
  14. Mar 17, 2013 at 8:50 AM
    Failure2Comply
    Virginia, USA
    Gentlemen, I did not want this to turn into a bashing of any sort. This is IMHO one of the biggest problems of conversing on the internet, people most likely would never say such things if we were all face to face. Member 127.0.0.1 (I think I got the "Home" octets right) has one of the best sig lines I have seen.
    Now back on topic. I decided to go with these Vulcan brand straps after someone who's opinion I value recommended them after decades of personal experience with this brand. My compact tractor only weighs in at 1800# so these will definitely carry the load. I use a 1/2" chain to secure the tractor to the front of the trailer and then feed the straps through the ROPS and cinch her down. I chose model #RS227W12 which are 2" x 27' and 3300# WLL (working load limit) and a burst of 10,000#. These are also UV resistant and stand up to the winters in Maine. Here are some specs from their website along with the website link for whomever is interested. Thanks to all for your suggestions.
    Heavy-duty industrial tie down straps
    Totally self contained tie down unit
    Certified polyester tie down webbing
    Bright yellow dye for easy identification
    Coated webbing for UV and cut resistance
    Heavy duty steel wide handle ratchet
    Hook on both ends for secure tie down on both sides of your load
    Coated end fittings for weather resistance
    Safe working load stamped on warning tag
    Hard to find, extra-long lengths available
    Meets or exceeds all DOT requirements"
    http://www.truckntow.com/p-10842-2-ratchet-straps-w-wire-hooks.aspx
  15. Mar 17, 2013 at 8:55 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Kinedyne makes great cargo straps. I use them almost daily to lift 10k lbs at work. Military tested and approved
    http://www.kinedyne.com/
  16. Mar 17, 2013 at 8:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The kind of statements you made have initiated JAG investigations when they have been made on this board in the past.
    In a budget climate where every wasteful or questionable expenditure will get scrutinized, I would not want to be the guy making "jokes" like that.
    And lets make this the last post about that...Lets talk just straps now.
  17. Mar 17, 2013 at 9:47 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Concur. Keep it at tow straps.
    I agree w/ dirtfondler. Wally may not be the place to go for quality made straps.
  18. Mar 17, 2013 at 1:38 PM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
    Give it a rest already. :rolleyes: Holier than thou keyboard warriors.
  19. Mar 20, 2013 at 3:26 PM
    Failure2Comply
    Virginia, USA
