need rr diff wire diagram. no life from actuator
Discussion in '1st Gen. Tacomas (1995-2004)' started by pdxwhiteout, Feb 25, 2010.
  1. Feb 25, 2010 at 7:39 PM
    pdxwhiteout
    pdxwhiteout [OP] monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    whats up guys? i need a wire diagram for my 2004 v-6 auto trd's rr diff system. light just keeps flashing and theres no life from the actuator. checked the switches on the transfer case and rear diff, both are operating as should. while open the dmm shows ofl and while closed i got 0.1ohms. so id like to check to see if im getting power and signal to the rr diff actuator. thanks for any help.......
  2. Feb 25, 2010 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Is what your looking for?
  3. Feb 25, 2010 at 8:06 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    just the man i was hoping to hear from:). perfect! thx chris. you are a true tw jedi master. ill test her out tomorow at work.
  4. Feb 25, 2010 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help :) also, You may want to check for debris inside the operating mechanisim. Sometimes the motor assembly gets crap in it, causeing this issue.
  5. Feb 25, 2010 at 8:26 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    good to know. i will check it out if im getting power/signal back there. thanks again for the help!
  6. Feb 26, 2010 at 7:00 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    first of all i wanna thank chris4x4 once again for coming through with the wiring diagram last night and making todays testing a breeze. now to the update, well things are not looking good:mad: after testing pin 3 at the actuator for a power signal, i found 0v:confused:. now knowing that is for sure a electrical problem i moved to the diff ecu. as expected i had power coming from the fuses into terminals 4 & 5. also verified the ecu's ground form terminal 8(grey wire). so then the bad news, nothing out of terminal 3 just like at the actuator. at this point im basicaly convenced its the ecu it self. got a freind at a local yota dealer looking in to it tonight, so fingers crossed:(.. if anyone sees something in the diagram above im missing please speak soon. thx for any help guys. chris are you out there? heeeeellp!:)
  7. Feb 26, 2010 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Send a PM to 98tacoma27....Also...One to Brunes....We need to get more "Brains" in this thread. OOO....Kevhodgaz..He knows these trucks like the back of his hand....
  8. Feb 26, 2010 at 7:44 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    All right, let's see if we can get this figured out.
    You said you had no power to the actuator, or power out of the ECU, right? Your light always flashes, and never goes solid. You have the transfer lever in 4Lo, and the 4WD light is on, too?
    My next step would be to check the 4wd switch, that tells the ECU the truck is in 4Lo. If this is always showing to be in 2 or 4Hi, the diff lock will not engage.
    The actuators rarely fail, and I don't recall replacing any ECU's either. As a matter of fact, I don't recall seeing any Taco's come in that the system didn't work on.
    I'm guessing it's something simple, and it should be pretty easy to narrow it down.
  9. Feb 27, 2010 at 6:54 AM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    all the above condition q's are correct. idling in 4lo with the button engaged. i did drive it in 4lo to confirm its operation so it for sure in 4lo and working. puts a :) on my face to hear you say youve never had an ecu go bad though! i did pull the switchs out and test them off the truck. they seem to be working with my meter showing ofl with the plunger/ball out, and the meter showing 0.1ohms with the switch closed(plunger/ball in). i tested both switchs this way. i assumed, hate that word, at that point they are working. just to make sure i will climb under and jump the harness to bypass the switch and see it the system engages. so im off to work boys:mad: hopefully i find time to try it today. thx for the help, ill report back.
  10. Feb 27, 2010 at 6:54 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    well jumped the switch on the transfercase and still got no life back there. jumped the switch on the diff and as expected the light stop flashing but theres still no power to the actuator..ideas????
  11. Feb 27, 2010 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take it out, and see if its got crap in it...
  12. Feb 27, 2010 at 7:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Kev covered the stuff i woulda asked...I'm outta this hunt all ready. Sorry amigo.
    Best of luck!!
  13. Feb 28, 2010 at 5:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you check the 4wd fuse? I didn't see mention of it.
  14. Feb 28, 2010 at 12:08 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    i didnt check the fuse. i guess i figured it was good since the 4wd is working. ill double check just to make sure though.
  15. Feb 28, 2010 at 8:09 PM
    kevhogaz
    SR5 PreRunner
    Look on page 2 of this troubleshooting PDF. It tells you how to isolate the ECU, and if it's bad. This is the exact same page out of our factory Toyota repair manuals, so with it, you should be able to figure out what's going on.
  16. Feb 28, 2010 at 11:44 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    thx kev.
    ill be back in the shop on tuesday and we'll get it figured out:).
  17. Mar 3, 2010 at 8:52 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    :mad:well i found the time to do the above diag and things are not looking good for the 4wd pcm. performed all the input test on page 2 of the above link from kev and found all input to be good. infact the only test that failed was the last one on the page, testing voltage between terminals m1 and m2 of ecu during switch operation. i got no changes in voltage at all, nor was there v's coming out of either terminal. so the last thing to do will be to pull the actuator out to service and bench test it to verifie its operation. i know i could just hook battery power up to it on the truck but im gonna take chris4x4's advice and clean it up real good. but if works which i think it will then ill need a known good pcm to install as seen in step (c,5). luckly i got friend at the local yota dealer that might be able to make that happen for me. wish me luck, my taco needs some:(
    big thanks again to kev and chris for coming through with tech info needed for all these test. thanks boys!
  18. Mar 3, 2010 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sorry to hear its not fixed yet. Im keeping my fingers crossed for ya.
  19. Mar 4, 2010 at 2:30 PM
    kevhogaz
    SR5 PreRunner
    What dealer are you taking it to? I used to work at Gresham Toyota, and was pretty good friends with a few guys at Broadway, and out at Royal Moore.
  20. Mar 4, 2010 at 5:13 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    i wont be taking it to the dealer to get it fixed, just to borrow a 4wd ecu real quick. i work at honda & we have a partner toyota dealer in wilsonville. so ill probably just have to drive down on one of my days off. but thank you for the offer.
