need seatbelt help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rhino, May 22, 2011.
  1. May 22, 2011 at 9:50 AM
    Rhino
    Rhino [OP] Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    my girlfriends dad and i were changing my stock speakers out in the back seat of my 2003 extended cab and when we unbolted the rear seatbelt it reeled all the way in and locked now it wont unlock any suggestions for this?
  2. May 22, 2011 at 10:26 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Normally if you pull real gently straight out from the retractor it will unlock. :notsure:
  3. May 22, 2011 at 3:36 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    I am not familiar with that specific seat belt, but most Toyota belts that I have seen have a translucent cover over the ratchet mechanism. The cover is usually marked "DO NOT REMOVE." If you remove that cover, you can release the ratchet and pull the belt out.
    For the future, always remember to clip something to the belt just above the reel, so it can't retract. I use a binder clip, but a c-clamp or vise-grips or a spring clip would work, too.
  4. May 23, 2011 at 8:37 AM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    thanks guys but it actually fixed itself we bolted the rachet part back in and it allowed it to release
