Need some advice for boosted 1GR rebuild.
Discussion in 'Performance and Tuning' started by MrMurse, Jan 18, 2019.
  1. May 19, 2020 at 3:16 PM
    MrMurse
    MrMurse [OP] Well-Known Member
    Riley
    St. George, Utah
    2006 Crew Cab TRD Sport Tacoma
    Turbocharger with all the fixins
    I suppose you're right. If you're going to do it, you gotta do it right. If what I have was working, maybe I'll rebuild it and use it until I save up for something newer and more efficient. I was checking out that calculator on borgwarner, it seems pretty powerful but I wasn't sure how to get a lot of the data they were asking for to make it accurate.
  2. May 19, 2020 at 3:21 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Torspd and MrMurse[OP] like this.
  3. May 19, 2020 at 6:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Save those pennies and get you a good one. It will be welllllllllll worth it!
    MrMurse[OP] likes this.
  4. May 26, 2020 at 1:55 PM
    MrMurse
    Riley
    St. George, Utah
    What should I do for break-in with regards to tune and boost? Should I just turn down the boost all the way and go easy? Hook up the stock ECU? Get a limp tune?
  5. May 26, 2020 at 2:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. You could pull the wastegate spring, so that you're not making any boost. If the turbo kit is on. Then with the stock injectors and OEM ecu, do your engine break-in. Change your oil. Then get it tuned with the HP Tuner.
  6. May 26, 2020 at 2:37 PM
    MrMurse
    Riley
    St. George, Utah
    Cool. I don't have any stock injectors though:(
    I just dropped off my valve covers to the builder, and I guess they're held up on gapping the rings. The guy I talked to asked what the max amount of boost I'd be running, and I'm not sure, tbh. What's the potential here? I told him 15 psi but then driving home, I was worried that I'd have tons of blow by if I'm not running near those numbers.
  7. May 26, 2020 at 2:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That'll be ok. Just check the oil fairly regularly to get an idea of how quickly it goes down, and you'll have your baseline.
  8. May 26, 2020 at 2:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What aftermarket ecu do you have for tye injectors that you have? What size are they as well?
  9. May 26, 2020 at 3:07 PM
    MrMurse
    Riley
    St. George, Utah
  10. May 26, 2020 at 3:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Then you can do the engine break-in with that. Just don't have any boost.
  11. May 26, 2020 at 3:15 PM
    MrMurse
    Riley
    St. George, Utah
    Sounds good, thanks again for all your wisdom!
    Torspd likes this.
  12. May 26, 2020 at 3:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Keep us in the loop, with how it goes once all together!
  13. May 26, 2020 at 3:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Jul 6, 2020 at 2:47 PM
    MrMurse
    Riley
    St. George, Utah
    I had an O2 sensor question. I have a bung in each exhaust manifold and one pre and post cat. I need to replace the two in the manifolds, one is missing and the other looks pretty rough. Should I just put stock sensors in both of those?
  15. Jul 6, 2020 at 2:57 PM
    #35
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes toyota/Denso is the way to go
  16. Jul 19, 2020 at 6:41 PM
    #36
    MrMurse
    Riley
    St. George, Utah
    Engine is in, primed it and went to start it with no luck. I'm checking all the usual suspects, but then my starter died. Feeling pretty unlucky tonight.
  17. Jul 20, 2020 at 7:26 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got a scan tool to check for any check engine lights?
  18. Jul 20, 2020 at 8:16 AM
    #38
    MrMurse
    Riley
    St. George, Utah
    Yeah, says no drivetrain codes. I lost my fuel pump relay when I took out the engine, and the replacement I put in has one less terminal. I don't hear the pump prime when I turn the key, so that's my top suspect. I'm going to pull out the starter and replace it this morning, and see if I can get a different relay.
  19. Jul 20, 2020 at 8:46 AM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely the suspect.
  20. Jul 20, 2020 at 5:49 PM
    #40
    MrMurse
    Riley
    St. George, Utah
    Got it running, started right up with the correct relay. I drove it down to the end of the street before I got a light, threw a P2196. Too rich. Should I continue with the break in or wait to have JustDSM tweak a tune for me?
    Torspd likes this.
