Need some advice on sliders (with step)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clc2112, Nov 19, 2014.
  1. Nov 19, 2014 at 6:18 PM
    clc2112
    clc2112 [OP] Well-Known Member
    Calvin
    San Jose, CA
    '21 Lunar Rock
    I just got a TRD pro that has a lift on it. While I am 5'5" I can hop in gracefully but my wife is 5'1" and this height will not be acceptable for her.
    I am looking at jumping in on the All Pro slider group buy and getting some Apex's. Ryan from AP sent me a link to a step:
    http://stores.streetacos.com/steps-clamp-on/
    This is supposed to bolt on to the Apex's.
    Is this my best option? My criteria are:
    1. Good TW friendly vendor
    2. Has a step or step can be added.
    3. Functional and looks cool.
  2. Nov 19, 2014 at 6:27 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Be aware that street tacos has quite a bad reputation, you should search this forum for threads discussing their poor business practices as well as product quality issues.
  3. Nov 19, 2014 at 7:39 PM
    clc2112
    Calvin
    San Jose, CA
    '21 Lunar Rock
    Thanks. All I need to hear. No further research needed.
  4. Nov 19, 2014 at 7:57 PM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    SOS Concepts
    I have a set of theirs on my '13 DCSB with kickout. VERY VERY satisfied.
  5. Nov 19, 2014 at 8:06 PM
    Pigpen
    Dan
    Northwest Montana
    just ask to have your APEX sliders welded without the upward angle. They'll be just like steps, but better. That's the route I plan to go.
