Need some assistance.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Xenuex, Nov 30, 2011.
  1. Nov 30, 2011 at 3:13 PM
    Xenuex
    Xenuex [OP] Member
    Brent
    (From WA)Stationed Camp Lejeune, NC
    1999 Tacoma
    So, I don't know why. But, I have been having some extremely bad luck with this Tacoma. I love it, and don't wanna get rid of it. But, I may have to once I get this issue resolved.
    Anyways, I have a 1999 Toyota Tacoma and I have been having issues with the power steering pump for ages. Anyways, I took it to a shop so they can replace the pump( I do not have time atm to fix it myself). And found out, that not only the pump is bad, but the pulley and the reservoir are gone too. I knew the pulley was going bad. I know this next part is not to smart, but I have been driving it without the bolt for the pulley. Yet, it remains to hold onto the pulley. Seems like it got pressed on.
    Anyways, to get to the point. I made a post earlier about parts online. I have checked every valid site I can find. I went to all the local stores, called stores back where I live, including all the salvage yards I could find. Both here in NC, and back home. I need to be pointed in the direction of a pulley and reservoir
    Does the pulley for a prerunner fit the tacoma. I know they aree different engine sizes. I am pretty sure all 4cyl prerunners are 2.4l and my truck is a 2.7. All 4x4's are 2.7l when 4cyl. And Same question for the reservoir.
    If not, I have only found one other choice, and that is a 1-2 hr drive back home.
  2. Nov 30, 2011 at 4:39 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    A salvage yard should be able to tell you if the pumps are interchangeable.
  3. Nov 30, 2011 at 4:43 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    Id vote look online on a toyota parts website to locate your part number for the needed items.
    Then cross ref that part number with that of the prerunner or other of your choosing. If the part number is the same, you are in bidness.
  4. Nov 30, 2011 at 4:49 PM
    2000prerunner
    2000prerunner Active Member
    Michael
    North DFW
    '00 Prerunner SR5
    Hella 500 FF's, Pioneer sound system, and More to come!
    Any 4-cylinder prerunner will have the 2.7l. I've got a 2000 prerunner with that engine. The 2.4l are on the 5-lug tacomas.
  5. Nov 30, 2011 at 4:57 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    (aberdeen used parts) 2107 ashmont rd aberdeen north carolina 1 800 422 8460 www.abredeenparts.com steve cagle at this place will do whatever it takes to get what you need
