Need some help...more like a small favor.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KingTaco81, Jan 18, 2017.
  1. Jan 18, 2017 at 6:38 PM
    KingTaco81
    KingTaco81 [OP] The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    My truck has been having problem with the abs actuator, it has this annoying buzzing/vibration in the pedal every 3rd or 4th time I press on the brake. When you open up the hood it's more noticeable. I took it in to the dealer and they said it's 100% normal which I know it's not not because it never did that. The squishy sound yes but not the buzzing/vibration. So... the tech said they need to find another 2013,14,or 15 to compare with mine so they can determine if it's normal or not. Thanks in advance. I'm located in socal.
    ChadsPride likes this.
  2. Jan 18, 2017 at 6:41 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The dealer doesn't have any on the lot? You should try another dealer if they're gonna hassle you like that.
  3. Jan 18, 2017 at 6:43 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    I went to 3 already. None on lot. So frustrating
  4. Jan 18, 2017 at 6:43 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Mine has done this since day 1.
  5. Jan 18, 2017 at 6:45 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    It's loud. Sounds like I have a phone vibrating on the floor board.
  6. Jan 18, 2017 at 7:29 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Smooth, steady and quiet brakes on my 13'. But sorry, Im not drivin to SoCal to show the dealer.
  7. Jan 18, 2017 at 7:33 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    They had a 14 sport on lot. But the braking system is different from the off road
  8. Jan 18, 2017 at 8:30 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Nothing even close on my 2013DCLB 4X4.
  9. Jan 18, 2017 at 8:54 PM
    JD_P
    JD_P Well-Known Member
    Terrebonne, Oregon
    2015 TRD Off Road Access Cab
    My 2015 has the squishy sound but nothing like the rest of your symptoms. I am out of state, so not much help. Good luck with a fix. Are you using stock wheels, have a lift or anything?
  10. Jan 18, 2017 at 9:28 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Aftermarket wheels 285/70/17 ,Icon c/o and aal. This started happening after I came back from trip up to Big Bear few weeks ago.
  11. Jan 18, 2017 at 9:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Are you taking this to a Toyota dealer?
    I'd be really scared if they were so uneducated on their own vehicles that they wanted another truck to "compare" to before they decide whether this noise is "normal" or not.
    DustStorm4x4 and ChadsPride like this.
  12. Jan 18, 2017 at 9:44 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Yea Toyota. I took the tech out for a test drive to show him that this happens in P,R,N,D,4x4. I popped open the hood so he can see the acuator vibrate/buzz when the brake is circulated every 3rd or 4th time....long story short I picked up my truck and advisor said they don't think there's an issue with my brake system but they need to find a truck with same system to compare
  13. Jan 18, 2017 at 9:45 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Meanwhile... I hope your brakes don't fail and cause a crash.
  14. Jan 18, 2017 at 9:48 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Yea tell me about it. It's raining for the next 4 days.
  15. Jan 19, 2017 at 3:59 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In my opinion it is the electronic booster pump. They should just replace it. It is normal for it to run when you apply the brakes, but it shouldn't be doing enough to feel a vibration in the floorboard.
  16. Jan 19, 2017 at 4:40 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    My 15 does not make the sound you are describing, if that helps you at all....
    I agree that's a shitty answer from the dealership.
  17. Jan 19, 2017 at 6:33 AM
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    Mine does this as well and my dealer told me it was normal
    jmaack likes this.
